Author Subject: Cam spockets
Puggered
So how the F*&^% does something like this happen?
Posted 16th Sep 2016 at 09:49
Dunno unless its been fractured at some point in its life whike being off the Car?
Do you have bent valves now?
Posted 16th Sep 2016 at 09:57
Puggered
Most certainly do Angry
engines not even run in.
what do 306's burn like?Whistle
Posted 16th Sep 2016 at 10:20
Shock
I have never seen one of these fail in this way before! The older style ones yes, but never these.
Posted 16th Sep 2016 at 14:57
mocinim
Smelly with a few small bangs one big bang lots of bubbling plenty of black smoke
And some screaming if you leave someone in the boot Smoke
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 16th Sep 2016 at 15:05
Puggered
stan_306gti6 wrote:
Shock
Over the years I've seen plenty of weird and wonderful failures but this has me stumped. I've never seen the later pulleys fail either and were crack tested prior to going on as well which is what really p*&^es me off.
The pulley has in effect exploded ripping the side out of the timing belt before the piece jammed into the cover. There was no bang, rattle, etc the engine just stopped.
think I might build a bonfire Wink
Posted 17th Sep 2016 at 04:16
Puggered
no bent valves Smile must have been kissed on the dick by a fairy
new sprockets and a cam belt and not a tap to be heard.
Posted 18th Sep 2016 at 14:09
That's pretty lucky!
How it happened though is a bit worrying...
Posted 21st Sep 2016 at 07:33
mocinim
Lucky !!!
Thats supercalafragalistic bud !jammy sod! Smile
Posted 21st Sep 2016 at 08:53
Puggered
Think I may have been the culprit.
While making this up, I might have cracked it while test fitting.
Posted 21st Sep 2016 at 14:07
What did you need that for out of interest?
Posted 22nd Sep 2016 at 07:30
Ben_W
Formerly gpm
Looks like a locking tool for a cambelt change
Posted 22nd Sep 2016 at 08:57
cully
locks the cam pulleys together so you can torque up the centre bolt to 40Nm
its a copy of the peugeot tool for the job
very much like the one i made myself Wink
Posted 22nd Sep 2016 at 10:20
Puggered
^ What he said
I used to have the genuine Peugeot kit but gave it away years ago
Posted 22nd Sep 2016 at 11:47
i doubt peugeot used one of those on the j4r and j4rs due to the adjustable pulleys, they need to be loose when you tension the belt.
Posted 22nd Sep 2016 at 13:25
tvrfan007
It's not used for anything other than the moment you crack/lock the cam pulley bolts. It doesn't interfere with the adjustment as it's already been removed.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 22nd Sep 2016 at 13:35
cully
check out the download section of this forum
find the document "XU10J4RS Technical Info"
look for page 8 Fig:6 Wink
http://www.306gti6.com/downloads/index.php?id=21
Posted 22nd Sep 2016 at 16:44
I've always managed to torque the cam pulley bolts without the need for one of those. There is generally always someone floating about that I can get to sit in the car with it in 6th gear and put the brake on.
Posted 23rd Sep 2016 at 17:12
far from ideal, puts a very high force through the tensioner, probably why I've seen the casting break off where the tensioner thread is.
I use one of these.
Posted 23rd Sep 2016 at 17:48
devere
I use one of these.
Same here. Never had a problem when using these.
Posted 23rd Sep 2016 at 19:49
I use one of these.
Really? So how do you undo/torque the bottom pulley bolt then? Lock the crank somehow I guess?
Posted 28th Sep 2016 at 16:27
yup.
well i use an impact driver man enough to loosen the bolts without turning the crank Big grin but otherwise a good screwdriver in the ring gear.
Posted 28th Sep 2016 at 17:57
I've always used the method I described without issue.
A screwdriver in the ring gear could cause broken teeth on the flywheel, not something I'd like to cause.
Posted 28th Sep 2016 at 22:03
lol, those teeth are designed to be hammered by a 1.4 kw starter motor.
Posted 28th Sep 2016 at 22:12
Not billet lightened ones though! LOL
Posted 28th Sep 2016 at 23:51
