Author Subject: Heater matrix pull through bulk head
fast_eddie
I know Im a retard at the best of times and ive looked at the guide lots of times but
How on earth do the two pipes for the heater matrix pull through bulkhead?
There is a kind of rubber mat material around the two pipes on the exterior bulkhead side and the matrix pipe has a lug on it that is preventing me pulling the unit through?
I dont want to break it by ragging it throughNo
Posted 13th Sep 2016 at 17:55
deeturbo
I think I had to pull the rubber grommet through with the matrix, then remove the grommet from the matrix.
Getting it back in was the worst part.
Posted 13th Sep 2016 at 18:45
fast_eddie
ok thanks-I kind of feared this would be the way forward!
It would be sooo nice if things were simple lol
Posted 13th Sep 2016 at 23:32
fast_eddie
ok, yes im a fecking retard!
I literally pulled and pulled and pulled on the heater unit until the top section of the matrix unit detached from the input pipes and snapped the fitting on the heater, leaving the two bulkhead pipes sitting in the bulkhead laughing at me and pouring coolant everywhere!
I even put gloves on for more purchase but hey!
Is there a proper way of getting these f**king things out from the bulkhead and more importantly , getting them back in again!
Thanks in advance
Posted 29th Sep 2016 at 00:30
mocinim
Wtf put a pic up bud not sure what pipes you refer to that cause this much grief
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 29th Sep 2016 at 08:59
deeturbo
Try using a flat head screw driver and try removing the rubber from the bulkhead.
Posted 1st Oct 2016 at 16:30
fast_eddie
This thing-Looks like some kind of neoprine or something--Cant budge it
fast_eddie has attached the following image:
Posted 6th Oct 2016 at 14:36
scotzman
Its just rubber and should pull through easily from the inside, its the refitting you should worry about, that's 100 times worse.
Posted 6th Oct 2016 at 15:40
fast_eddie
Ok well ive already snapped the pipes( as mentioned somewhere else its easy to do that) but I have swung 14 stone on the f**king thing and I cant pull it through---Bigger man needed lol!
Are ph2 and ph3 heater/aircon units the same? ie connections and pipes?
Posted 6th Oct 2016 at 16:32
Are you going in dry? LOL
Plenty of lube around the pipes and the rubber they come out easy as anything.... as said getting it back through PROPERLY is a c**t....
Posted 6th Oct 2016 at 22:08
fast_eddie
Lol ive 'squirted' wd40 everywhere but ill try something a bit stickier lol
Posted 6th Oct 2016 at 22:16
