Thanks in advance
2000 W Phase 3 Moonstone.
| Author | Subject: Team Dynamics 1.2 Wheel Bolts |
GTi6-PJL
Regular Location: South Essex Registered: 30 Sep 2013 Posts: 144 Status: Offline |
As per the title, can anyone recommend the best bolts to use on these wheels (16 inch, ET 15). I've seen a few posts mentioning tuner bolts however most of the links are dead, and I don't want to buy the wrong ones!Thanks in advance ![]() ________________________________________ 2000 W Phase 3 Moonstone. |
demondriverdan
You need tapered bolts rather than flat faced ones that come with Cyclones (and other wheels). Can't remember where I got mine from, think I took them from a car in a scrap yard!________________________________________ Rallye Race Car |
c5 wheel bolts would work, anything with a 12x1.25 thread and a straight 60d taper seat.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
GTi6-PJL
Welshpug - thanks for that. I see the C5 bolts are 26mm long - I've found some tuner bolts which are 28mm - I assume these will be OK? Only looking at tuner bolts as I can source these far cheaper than the C5 bolts, plus they have the additional benefit of being harder to nick (in theory at least).________________________________________ 2000 W Phase 3 Moonstone. |
janne l
Newbie Location: Stockholm Registered: 14 Jun 2010 Posts: 15 Status: Offline |
I'd recommend going for 17mm hex, i find that the bolt holes are quite narrow, and my 19mm socket fouls on the inside.________________________________________ Peugeot 306 GTI -97 Stripped out trackday toyPeugeot 307 SW Griffe -05 Peugeot 206 1,6 Griffe -04 |
get a wheel socket, they are slimmer________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Cjwatson27
In wouldn't use those McGuard bolts things either mine fell apart and had to be drilled off ________________________________________ Old pugs don't die they just get faster |
janne l
welshpug! wrote: get a wheel socket, they are slimmer That's what i've got, still narrow ![]() ________________________________________ Peugeot 306 GTI -97 Stripped out trackday toyPeugeot 307 SW Griffe -05 Peugeot 206 1,6 Griffe -04 |
