Author Subject: Miles gear linkage FAQ?
sergioiacobucci
Hi Guys,
Is there an FAQ on how to fit these anywhere? I am trying to work out how hard it is. Have been looking into the Satchshift however that seems a nightmare to fit and people seem to have some problems with them that they then need to solve, so have gone off that idea now.
If anyone know roughly how you fit them that would be super useful, cheers Thumbs up
Phase 1 silver track car
335i daily
Posted 3rd Sep 2016 at 21:18
martinh
Very easy to fit. Pop off the old linkages, I use the open end of a 14mm spanner from memory, do one at a time if you're likely to get confused but they only fit one way.
Remove the retaining pin from the new linkages, Small dab of grease in the ball of the new linkages, line them up and apply a small amount of pressure till it seats, re insert the pin and repeat the process for the remaining 2!
Will take you 10 minutes tops unless you drop a pin!!
Posted 3rd Sep 2016 at 21:23
sergioiacobucci
Great thanks!
Probably a stupid question but how do you access them? Easy to get to?
335i daily
Posted 3rd Sep 2016 at 21:27
pugheaven
Satchshift is easy to fit it's just time consuming.
The revised boot has been out for ages now, the only issue I had with mine is that it likes to undo it's self but thread lock sorts that out
Posted 3rd Sep 2016 at 21:34
mocinim
If there adjustable you can set the up to your liking with regards to the gear stick positioning
Also if you dont grease the balls properly they mayl rattle,, tip!!
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 3rd Sep 2016 at 21:40
manthos
think i removed battery box maybe not, I didn't use anything but my hands just pulled the old ones off and pushed the new ones on.
Team SUPERCHARGED
Old Project thread
Posted 3rd Sep 2016 at 21:45
sergioiacobucci
Thanks.
Pugheaven I think your version of easy to fit is different to mine!
Thanks for the tip mocinim, easy to get access to?
335i daily
I don't recall removing the battery box to do mine, its a slightly fiddly job. The most frustrating thing is trying to line up the pins to put them in, or dropping them as already mentioned.
Posted 3rd Sep 2016 at 21:52
manthos
ok do even easier just make sure engine is cold as your arm will be up against the exhaust manifold.
Team SUPERCHARGED
Old Project thread
Posted 3rd Sep 2016 at 22:04
mocinim
sergioiacobucci wrote:
Thanks.
Not to bad for access if your going to make adjustments id pop the battery box out makes life much easier or put it on ramps and do it from underneath
Posted 3rd Sep 2016 at 22:22
sergioiacobucci
Thanks all - doesn't sound too bad then!
335i daily
Posted 3rd Sep 2016 at 22:28
mocinim
Easy job chap simples Smile
Posted 3rd Sep 2016 at 22:31
