Author Subject: Various parts
Denis
Powerflex bottom engine mount, £30 posted I found it to be a good compromise between a standard mount and full hard rubber mount (i.e. Baker BM). sold
Coilover top hats 2.25", £15 posted sold
Peugeot 205 adjustable top mounts, used briefly on my Rallye, £60 posted
Serviced injectors (ultrasonically cleaned, new seals and caps), £60 posted sold
Rallye steering wheel (airbag not included)
Removed from my Rallye @ 35k miles, when it was 5 years old and has been in storage for the past 12 years, £60 posted
Rear brake hose for Ph2 cars: TRW PHA326C (Peugeot part number 480664: right, 240mm long) £7 posted sold
Heat exchanger, £25 posted
1.9 TD engine main and big end bearings, crank and cam seals. Any interest in the lot?
Bosal catalytic converter. In good working order, £45 posted sold
3x standard pistons machined by Bridgecraft to run with Kent PT81 cams. There was a slight contact with inlet valves (happened after the head was skimmed during head gasket repair). Any use for anyone?
Complete inlet manifold with throttle body and all sensors (can be supplied with Ph1 or Ph2/3 map sensor). £60 delivered
In case somebody wants to contact me directly, my email: ds_ext at cantab.net
Cherry Red Rallye Project thread
WhiteBMW M140i
Posted 7th Sep 2016 at 21:35
I'll take the top spring cups please
Posted 2nd Sep 2016 at 07:40
I'll take the brake hose
Posted 2nd Sep 2016 at 08:18
Denis
List updated and some new bits added.
WhiteBMW M140i
Posted 4th Sep 2016 at 17:44
