Author Subject: Coilover not central
pugheaven
Noticed this a few times and have never done anything about it but think its about time I see what I can do to sort it.....
Basically the spring seat is not sitting central on the top mount bearing.
(Gaz coilovers using standard top mounts)
I can get a pic if need be but just wondering if anyone else running coilovers have noticed the same
Posted 22nd Aug 2016 at 20:00
pugheaven
Posted 22nd Aug 2016 at 20:10
mocinim
I would suggest sir that your bearing is in upside down
Does the bearing lip point down ???
Kind or hard to see from the pic
When they package and send out top mount n bearing kits they place the bearing in upside down
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 22nd Aug 2016 at 20:43
pugheaven
Really, well I'll be f**ked!
I didn't build them up as my compressor was out of action so took them down to a garage to replace the top mount!
Driven 2000 miles like that and 2 mot's!!!
Posted 22nd Aug 2016 at 20:52
mocinim
http://www.306gti6.com/forum/showthread.php?id=164593&page=2
This is a more severe case was apparently clicking alot
mocinim has attached the following image:
Posted 22nd Aug 2016 at 22:25
mocinim
Is this lip pointing down
Posted 22nd Aug 2016 at 22:29
Yup looks like your bearing is upside down. I have gaz golds on mine and their fine with standard mounts people assume because there's a slot cut into the top mount that the bearing does actually fit into the wrong way up that's the way they go....
Posted 22nd Aug 2016 at 22:40
you don't need spring compressors for these
Posted 22nd Aug 2016 at 23:05
pugheaven
Haven't had a look but I can garentee the muppets at pro tyre have fitted the bearing outer race upside down like you have pointed out!
My air compressor is up and running so I'll sort it out tomorrow.
Na definitely won't need spring compressors as when the weight is off the springs are loose
Posted 22nd Aug 2016 at 23:09
shabusta
thank you, i'm not the only one that made this mistake! FYI those are my red coilies Wink
the clicking was from having the tie rods incorrectly bolted on.
Posted 5th Sep 2016 at 11:49
