Author Subject: Rad relocation
fatlapit
Has anyone ever mounted the rad in the rear or know of a rear mounted rad car?? Im trying to gauge the size of vent required to feed a rad. Ive also thought about lying the rad flat and venting out the boot floor. But just getting the air to the rad might be hard.
Posted 16th Aug 2016 at 09:38
mocinim
Im guessing youd need a stronger water pump also
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 15th Aug 2016 at 19:58
fatlapit
Well looking at the drifting forums. It doesnt appear so
Posted 15th Aug 2016 at 20:07
Moved to Engines. Smile
Posted 16th Aug 2016 at 09:39
RallyeP6
Mounting on the boot floor, with a venturi sucking the hot air out towards the rear of the car could be interesting. Though you would still need a fan at low car speeds. Then again, drifting sideways would mean the venturi (diffuser) would not be at the correct angle, humm.
Posted 16th Aug 2016 at 09:42
fatlapit
As a circuit car will it work. Also there will be a need for a clio v6 esc vents to help direct the air
Posted 16th Aug 2016 at 10:22
Cjwatson27
You can get those window duct things
Posted 16th Aug 2016 at 10:32
fatlapit
Got a link
Posted 16th Aug 2016 at 10:42
Cjwatson27
http://www.plastics4performance.com/naca-duct.html
Posted 16th Aug 2016 at 10:48
fatlapit
X2 of them in each window may work
Posted 16th Aug 2016 at 12:02
fatlapit
76mm
Cjwatson27
Looked into doing this with my mini turbo and venting out the boot lid, I was going to run a electric water pump. There's a few of them on the mini forums
Posted 16th Aug 2016 at 12:34
