Author Subject: Single fan replacing twin fan
demondriverdan
Is there anything you need to do when swapping a twin fan for a single fan? I assumed everything would just work but obviously being Peugeot, that would be far to easy
Rallye Race Car
Posted 11th Aug 2016 at 16:30
find a single fan loom from a rallye or similar and fit a thermoswitch in the rad.
Posted 11th Aug 2016 at 16:31
demondriverdan
The loom that goes round the engine bay (as opposed to the engine loom)?
Surely it's easier just to fit a slimline fan?
Rallye Race Car
Posted 11th Aug 2016 at 16:34
cully
single fan loom would be easyer as the
twin loom Relies on relays to switch from slow to fast speed this Relies on two fans being present
with a single fan you wont get the ability of the slow speed unles you use a shunt resistor which the single fan loom comes with
Posted 11th Aug 2016 at 16:49
demondriverdan
Ah, ok. Bit of a ballache, was hoping it would be a straight forward swap!
Rallye Race Car
it is, the loom plugs into the front end loom, its about 2 foot long
Posted 11th Aug 2016 at 16:54
demondriverdan
To be clear, you're talking about the loom that goes from the plugs down in the nearside arch up to the engine? Or the loom that goes from that point back to the bulkhead and includes lights, etc.?
Rallye Race Car
Posted 11th Aug 2016 at 16:56
neither.
fan loom.
Posted 11th Aug 2016 at 17:51
cully
fan loom is hidden in the fan cowl
the multisocket is fixed to the lower N/side corner of the fan cowl
the plug for this comes from the loom running under the lower front cross member
Posted 11th Aug 2016 at 18:48
