Author Subject: Seam welding subframe
cully
when peeps seam weld the frames do they stitch them like 30mm gap 30mm or continual weld the seams?
and do they do all the seams or select ones?
I ask as ive started welding a spare frame i have and will be rebuilding it back up once done
Posted 9th Aug 2016 at 16:00
tvrfan007
I had everything fully welded, no stitches. Pics from my project:
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 9th Aug 2016 at 16:49
mocinim
I would imagine welding everwhere that wouldnt case issue to be the best plan
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 9th Aug 2016 at 16:52
janne l
I did mine about 30/30 mm, seems to work well!
Peugeot 306 GTI -97 Stripped out trackday toy
Peugeot 307 SW Griffe -05
Peugeot 206 1,6 Griffe -04
Posted 31st Aug 2016 at 11:43
I've been told to go careful fully welding it in one go ?....the heat distorts it .....
Stitch weld it & let it cool down...then move to other parts ..then fully welded finally
Posted 31st Aug 2016 at 14:39
cully
won't be welding it in one go as my argos welder cuts out on over heat Razz
Posted 31st Aug 2016 at 15:23
fast_eddie
Just about to do this to mine-Is there any difference between any of the 'phase' subframes?
Posted 2nd Sep 2016 at 02:07
I reccomend arc welding it as it struggles less with the rust and oil that gets trapped in the layers of spot welded metal.
Posted 3rd Sep 2016 at 20:50
cully
I am stick arc welding it Wink
Posted 3rd Sep 2016 at 21:51
pete_rallye
I had this problem with my mig, despite cleaning it thoroughly the oil and crap between the 2 sheets of metal were a real headache when welding it. Only thing I could think would be to acid dip it but not really worth it for most i doubt.
But I stich welded mine, 90% of the strength, but only half the extra weight of the weld.
Lap of the 'ring
Posted 3rd Sep 2016 at 22:32
