Author Subject: Potential jobs whilst I have a bare shell?
fast_eddie
Im in the middle of reshelling my 6.
The interior and the engine and running gear are off.
Obviously, I'm going to rust treat and rust prevent the underside and engine bay and put in new brake lines.
Ill also be powder coating the subframe, front panel, front ARB and all the other little brackets Ive disassembled from the donor car.
Are there any little hints or tips that I can gather up maybe before I put everything back on the shell?
The car will be a road car through and through, ultimately getting a high boost SC engine.
Jon
Posted 7th Aug 2016 at 22:29
RetroPug
Heater matrix springs to mind.
mocinim
Power steering ram and rack boots !!
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 7th Aug 2016 at 23:05
fast_eddie
Thanks so far Smile
Ive also got a xsara 2.4 rack with new boots and bag ready to go too!
Both drive shafts re booted and greased and Im going to get new wheel bearing all round too.
Posted 8th Aug 2016 at 00:00
mocinim
Subframe mount cups bolts screws etc .the cups are no longer available new and the bolts are now only available as facelift although there the same as many other models
Posted 8th Aug 2016 at 07:50
tvrfan007
Seam weld the subframe.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 8th Aug 2016 at 21:28
Ben_W
Formerly gpm
Does seam welding the sub frame make a huge amount of difference?
Posted 8th Aug 2016 at 22:19
mocinim
Yep not massive but !! for stiffness although the vts subframe is built stiffer and appears identical with regards to all other fitments so id try this instead if i was re shelling for track
Posted 8th Aug 2016 at 22:28
fast_eddie
Seem welding subframe--Job on the list!
Posted 9th Aug 2016 at 00:02
I had mine seam welded - seemed to stiffen the front end up under hard cornering. I liked it.
Posted 9th Aug 2016 at 15:41
