Author Subject: Ph 2.5 to 3 wiring loom advice
fast_eddie
I have taken ownership of a phase 2.5 shell to re-shell my phase 3 rusty old battered 6.
The interior is missing apart from the dash and the wiring loom has been cut in many places, including both sides of the dash.
I have the loom that's been cut and can obviously re solder it together ( i understand the future complications of that task) but I wanted to know what kind of job it is to remove my wiring loom complete from the phase 3 car and drop it whole into the 2.5.
The fuse box looks completely different in both and I also wondered if I could leave the engine bay loom in and still hope to connect it all together and tun the key and everything works?
Im guessing, I need to fully pull out my phase 3 loom for the reshell to work properly but im hoping someone might have time saving advice for meThumbs up
Thanks
Posted 6th Aug 2016 at 21:47
mocinim
Take the lot bud 2.5 and 3 are different in many ways personally id think it easier even the door loom wiring may be different or at least arranged different at the pins
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 6th Aug 2016 at 22:15
cully
as said ph2 loom is very different
yes even the door looms are different
yes the engine loom is different but interchangeable with sensor swaps
yes the engine bay loom is different
yes the dash loom is different
yes the body loom is different
Posted 7th Aug 2016 at 08:35
pug_306
Phase 2.5 engine loom is same as phase 3 iirc ?
Think the dash loom is the same also as they both use the later 2 plugs on the transponder ?
1992 205 GTi6
205 Turbo 340bhp
Posted 7th Aug 2016 at 08:43
depends how late the 2.5 is, like Ryan said, it might already have the integrated 2 plug RF type central locking/alarm control unit and transponder.
Posted 7th Aug 2016 at 09:44
fast_eddie
Many thanks guys!
Just about to start pulling everything out to have a look
cheers
Jon
Posted 7th Aug 2016 at 12:59
fast_eddie
Found a little box under the ph3 drivers side carpet which the ph2. 5 doesn't have.
Guess it's full loom swap out!
Posted 7th Aug 2016 at 15:55
fast_eddie
Is the rear o/s C pillar loom the same-Looks like the connections are identical for hrw etc?
Posted 9th Aug 2016 at 17:55
fast_eddie
Does the ph3 wiring loom split anywhere around the fuse box before it goes to the engine bay.?
Posted 18th Aug 2016 at 10:15
cully
there is a large square plug on the bulkhead under the windscreen wiper-motor which splits the front engine loom
Posted 18th Aug 2016 at 10:33
fast_eddie
Thank you , that helps my re shell thought process massively!
Unpick all the loom from the shell, from the parcel shelf speaker connection to the larger square plug you just mentioned , then refit it all into my new shell, then new interior in , then work on engine bay and loom..
Posted 18th Aug 2016 at 23:18
