Author Subject: Weird engine noise...
oliverharveyuk@hotmail.co.uk
I was wondering whether this was what the engine sounds like normally when idling? To me it doesn't sound great and has a screechy rattly noise... It clears when the throttles opened up and runs great but would be good to hear off someone with more experience. Below is a video of the engine running and when opening the throttle a little:
https://youtu.be/FQ6gu1r2FDw
98 Blaze 6 - Current
Posted 3rd Jul 2016 at 02:27
scotzman
Idle sounds normal to me.
Posted 3rd Jul 2016 at 06:22
aaron6
Sounds alright to me too. Although the injectors seem pretty noisey
Posted 3rd Jul 2016 at 09:49
sergioiacobucci
That sounds very different to mine. I know what you mean, the kind of high pitch metallic noise.....no idea what that could be
Phase 1 silver track car
335i daily
Posted 3rd Jul 2016 at 10:39
mocinim
Sounds fine could clean everything inlet internals change the gasgets new sparks refreshed injectors o rings etc and it may sound smoother the inlet sounds like it has a ball bearing rattling around inside which is normal managed to get one of mine quiter by doing the above Smile
Oil change may also help Smile
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 3rd Jul 2016 at 10:53
Could be heat shield on the back has split
Posted 3rd Jul 2016 at 11:03
Thanks everyone guess it was just me being paranoid, the heat shield is stainless steel which is new so it may reverberate off it a little and made me notice it a little more, may look at replacing the injectors then
Posted 3rd Jul 2016 at 12:53
aaron6
They are all a bit ticky to be fair. I wouldn't worry too much about changing them. That being said though, I swapped mine and it definitely goes better. Nossles must've been worn not giving such a good spray pattern or something.
Posted 3rd Jul 2016 at 15:26
injectors rarely wear out on these but they can get very grubby, getting them cleaned professionally will fix them.
tappets can and do get noisy with age now, but a full stripdown clean and re-assemble can make an engine significantly quieter, unfortunately thats nigh on a full top end rebuild but can be done in situ.
Posted 3rd Jul 2016 at 15:39
