Author Subject: Stripped thread cam covers/head
This is more of a heads up
For years the thread in the alloy block has been gradually stripping
Allowing oil to escape and make a mess at the back of the engine!
I had to look it up but used a Sealey thread repair kit
Which just involves drilling out very carefully re-tapping
Screwing in a threaded coil and allowing you to put your original
M6 1mm pitch thread bolt back in good as new!
Here's a few helpful pix
The bolt here could just be pushed in and out
Masked off the cams to make sure no burs end up in the engine
If you've never tapped a thread before make sure you're dead strait
Turn slowley you'll feel it cut
Turn about a quarter/harf turn and back up taking your time! And blowing out the burs
Then screw in your coil using tool provided
The bar can be proken off once in place!
And in it goes good as new! If this helps just 1 person
I'll be happy
I paid about £16 for mine,.. You can get them for £4 or there about but this was something not worth skimping on
Posted 23rd Jun 2016 at 21:09
nice work, worth bearing in mind that the torque setting for these is quite low.
Posted 23rd Jun 2016 at 14:21
The bolt was like slinging a sausage down a hallway so I had nothing to loose it doesn't need to be tight to be honest just enough to asert enough pressure to stop oil getting out!
Posted 23rd Jun 2016 at 14:54
mocinim wrote:
Nicely done extra tip using a magnet to complete delicate work areas is also advised
Its an alloy head I don't think a Magnet would work?
Posted 23rd Jun 2016 at 14:56
mocinim
Fair point sir will retract
So used to tapping steel
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 23rd Jun 2016 at 14:59
LOL
Posted 23rd Jun 2016 at 15:48
