Author Subject: Fires Then Instantly Dies.
scotzman
I have a bit of a weird one, when I start the car from cold it sometimes fires as normal the instantly dies, second start it will start as normal, I can catch it if I'm fast enough to blip the throttle, other times it will fire, idle lumpy for a few seconds then return to normal.
The weird thing about this is that it only does it when using super unleaded, if its run on standard 95 RON fuel it starts and idles perfectly, I've tried it a few times switching back and forth between fuels to confirm this.
Any ideas?Dunno
Posted 13th Jun 2016 at 20:29
Try your stepper motor (idle control valve)
If that has caput the car will fire up then die!
Posted 13th Jun 2016 at 20:33
mocinim
Think its a case of go through the sensors change each out till it cures
Can you get it plugged in anywhere
Does it usually happen after refulling or just at anytime
Icv map lambda injectors coils sparkplugs ????(?
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 13th Jun 2016 at 20:38
scotzman
Why only when its running on super unleaded though?
Posted 13th Jun 2016 at 20:37
scotzman
Anytime but only when it has super unleaded in it, standard fuel and its perfect.
mocinim
Higher octane hotter burning temp bigger explosion different exhaust emmisions
Lambda may not approve icv maybe sticky not as reactive as it should be map sensor maybe bolloxed
Id go for the icv first is yours a marelli
Posted 13th Jun 2016 at 20:44
scotzman
Yep it is, I was going to change it anyway as I have occasional other idle issues, it was just the fuel thing that was throwing me.
Posted 13th Jun 2016 at 20:55
walker_texasranger
One of my old cars absolutely hated 98RON, used to misfire and all sorts of I stuck the stuff in, was fine on 95 Smile
Hilux InvincibleX daily
306 No.13 Doh
Posted 13th Jun 2016 at 21:11
sergioiacobucci
I'm having similar issues. From searching there's loads of things it could be, people tend to say ICV pretty quickly but i haven't read people having much luck with that. The potential reasons I've seen are:
1. ICV
2. Green Temp Sensor (one for ECU, I'm about to fit a new one to see if it's that)
3. Blocked fuel filter
4. Lazy fuel pump (try priming it twice see if it starts better)
5. Poor earths
6. Lambda (but haven't seen this much)
7. Lazy battery with poor crank (I think this is contributing to my problem)
8. Map sensor
9. Crank sensor
Not too many! Is yours decatted out of interest?
Phase 1 silver track car
335i daily
Posted 13th Jun 2016 at 22:08
mocinim
1. ICV
5. Poor earths
8. Map sensor
9. Crank sensor
Id go icv then map then lambda if there not all original parts e.g marelli bosch id change them anyway had an xsi once that had a iffy lambda had many running issues until i put the original in the other lambda was a new one just pattern part was pants
Posted 13th Jun 2016 at 22:18
scotzman
Its still running a cat, I did think of replacing the green sensor, I haven't gotten round to it yet but I did compare the resistance of a known good one after sitting it on the thermostat housing for a good time so it was at the same temp as the one fitted and it gave an identical reading.
Oh, and I have tried priming the pump a few times in a row, made no difference.
Posted 13th Jun 2016 at 22:32
sergioiacobucci
Report back on how you get on. Would be interested to hear.
335i daily
Posted 13th Jun 2016 at 22:42
Cjwatson27
I had this once check the plugs mine were really coked up from over fuelling caused by that green sensor not working
Posted 14th Jun 2016 at 08:00
scotzman
Just a quick update, I seem to have cured this, new oe green sensor and new Bosch map sensor. They were replaced together so I'm not sure which was to fault.
Posted 4th Aug 2016 at 18:06
