Author Subject: OK, so what next??
Tarmac terror
Having the Rallye pass it's MOT today and back on the road I'm wondering what to do to it next...
Already has...
Refurbished front suspension (rods/bushes/mounts)
Bilstein front/GAZ rear shocks
Braided brake lines
21mm Torsion bars
17" OZ's
Quickshift lever
strut brace
K&N induction kit
Momo steering wheel
Scorpion exhaust system
Having strong feelings towards fitting a Maxi kit in the longer term but wondered what you guy's thought about more shorter term mods that would make a difference....
Any thoughts??
TT
Posted 24th May 2016 at 23:45
aaron6
Big brakes I reckon. I'm not really a fan of the maxi replicas
Posted 25th May 2016 at 06:25
Better brakes,lighter wheels
Posted 25th May 2016 at 06:45
blandy
Bigger rear arb
Posted 25th May 2016 at 07:08
manthos
rich W flywheel and crank pulley and miles solid gear linkages
Team SUPERCHARGED
Old Project thread
Posted 25th May 2016 at 07:14
better rear dampers good tyres snd just drive.
Posted 25th May 2016 at 08:35
3rd time lucky
Brakes, then if funds allow, diff.
BLACK RALLYE - Sold
CHERRY RALLYE - new toy
Posted 25th May 2016 at 11:04
Tarmac terror
Thanks folks...
Brake-wise the plan is to use the front 4-pots from my Skyline GTR when I fit the Wilwood 6-pots I have waiting to go on. Should take care of front braking.
Like the diff idea...will keep my eyes peeled!!
TT
Posted 25th May 2016 at 11:26
GTi6-PJL
I'll second the Rich W flywheel & crank pulley suggestion. It really makes the engine so much keener to rev with these fitted.
2000 W Phase 3 Moonstone.
Posted 25th May 2016 at 11:52
mik
I would definitely put a Xsara VTS steering rack in - I've done that to mine and it is epic. I'd think about a Quaife diff and maybe the flywheel/crank pulley as these mods add to the lighter/keener Rallye concept.
Second the better rear dampers suggestion.
Wouldn't do the Maxi kit. You can go too far with a car with mods for the sake of it. A well-sorted Rallye is brilliant without over-egging it.
Some cavity and surface wax on/in underside bits to protect them is a good idea.
Also, give it a really good polish and clean inside and out, drive it and enjoy it.
Cherry Rallye SOLD
Posted 25th May 2016 at 13:22
Cjwatson27
I was tempted with the maxi kit and wide track but had concerns has to how long it was going to last has a road car before it started getting damaged. I spent the money on big brakes and wheels and hopefully decent tyres in the end and hopefully getting it finished for pug fest
Posted 25th May 2016 at 14:25
Tarmac terror
Noticed a guy on Ebay doing VTS racks...
ebay.co.uk/itm/POWER-STEERING-RACK-RHD-CITROEN-BERLINGO-XSARA-ESTATE-PEUGEOT-PARTNER-TSK5023-/121731678042?fits=Model%3AXsara%7CCars+Type%3A1.8+VTS&hash=item1c57c5ff5a:g:ZHsAAOSwyQtVzvAJ
If they're £85 new (WITHOUT exchange) why are these going for big money on here??? is this the same rack?
TT
Posted 25th May 2016 at 15:07
GTi6-PJL
TT - I don't think that is a proper VTS rack. The Xsara VTS came with the 2.0 not a 1.8 as stated in the ad, so I suspect that'll be a standard Xsara unit.
They fetch big money on here because proper ones are rarer than hens teeth!
Posted 25th May 2016 at 15:19
Tarmac terror wrote:
K&N induction kit
TT
is that one of those that you've just hung down the back of the Radiator?
unless their closed in the suffer from heat soak instead of drawing nice cold air the engine likes they draw in hot air and hinder more than help!
Posted 25th May 2016 at 15:25
Tarmac terror
K&N induction kit
TT
Yes. Although I've moved it back and left a little nearer the exhaust manifold so I don't suffer from throttle body icing in the winter...
TT
Posted 25th May 2016 at 17:19
deeturbo
After some of the options above, what about boost?
Low boost super charger.
Posted 25th May 2016 at 21:20
RetroPug
Smaller wheels?
Posted 25th May 2016 at 21:27
manthos
FTW
Team SUPERCHARGED
Old Project thread
Posted 25th May 2016 at 21:40
Tarmac terror
Thought about a SC.....
Might be on the cards if I dont decide to do a Cosworth 4X4 transplant!!
Options, options....
LOL
TT
Posted 25th May 2016 at 21:44
Roller bearing wishbone bushes bigger rear Arb big front brakes..... weight saving.
Then charger....
Posted 25th May 2016 at 21:49
RallyeRed
I'm sure 15" wheels and the best tires available would improve the drive no-end...
Posted 26th May 2016 at 09:10
Cjwatson27
I always thing aftermarket 15in wheels look lost in the 306 arches
Posted 26th May 2016 at 09:32
DRIVE IT>
Posted 26th May 2016 at 11:41
Tarmac terror
Don't really see the point of doing that TBH.....handles well with the 17's as it is.
TT
Posted 26th May 2016 at 11:46
Spot on! nice lightweight 7x15 alloys with decent tyres will make a massive difference over the standard cyclones Thumbs up
Posted 26th May 2016 at 11:47
