Author Subject: start trouble
manthos
Once the car is up to temperature after you have driven a little if you then turn it off for example you pull up to put some fuel in, when you come to turn it back on again it dies. always turns on from cold fine everytime. Once warm it will turn on and as revs drop immediately die
Team SUPERCHARGED
Old Project thread
Posted 9th May 2016 at 18:21
mocinim
Lambda or icv id say i believe they talk to each other to regulate the fuel mix would try icv first
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 9th May 2016 at 23:33
icv has no control on fuel mix, only idle speed
Posted 10th May 2016 at 06:36
mocinim
Cheers mei good to know
How does the icv know how to respond to required airflow
Posted 10th May 2016 at 09:23
mocinim
Would still try swapping the icv if you have one available my icv did simular had to change it
Posted 10th May 2016 at 09:24
RetroPug
ICV can cause stalling when warm. If you don't have a spare try cleaning it as well. Is your idle actually lumpy as you were discussing in the other thread?
Posted 10th May 2016 at 09:30
TPS Vs RPM.
Posted 10th May 2016 at 09:50
manthos
The needle stays perfectly still but it sounds a bit lumpy as if it's cammed
Team SUPERCHARGED
Old Project thread
Posted 10th May 2016 at 09:52
cully
air leak will cause this as the ICV cant keep up with the changes
spray some brake cleaner around the manifold joints and vac pipes listen for engine note change
i had a similar issue with a PTFE Throttle body gasket leaking only when hot,
car used to stall all the time when hot not at all when cold
Posted 10th May 2016 at 10:13
manthos
Thanks Cullybackey yes I had a slightly similar thing on my first 6 and it was an air leak so I was also thinking this might be a possibility I will try
Team SUPERCHARGED
Old Project thread
Posted 10th May 2016 at 11:52
I had this on my low boost mate.
I believe it's down to the fact that on a standard car the ICV only has to control the idle air from the throttle body into the manifold plenum and that's it.
However, on a charged car it has to control that area of volume as well as the volume in the charger, pipework and intercooler which is a much larger volume of air to control - thus the ICV cannot cope.
This used to be the general school of thought anyways.
Posted 10th May 2016 at 20:54
manthos
So basically the only way to fix it is to go stand alone ecu as the icv will then not be needed?
Team SUPERCHARGED
Old Project thread
Posted 13th May 2016 at 07:24
