Author Subject: Starting issues
mocinim
Hi gents the six has an issue with starting if its left for a while e.g 1 day i have to crank it for a while before it starts
Am thinking fuel is draining back down the pipe perhaps
And requires time for the pump to send it back up
Starts stright away after trips e.g shops short stops of a few hours
Any ideas gents cheers
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 9th May 2016 at 00:19
mocinim
Anyone ???
Posted 9th May 2016 at 14:48
cully
try priming it twice next time see if that helps maybe fuel pump getting lazy
Posted 9th May 2016 at 14:59
Sounds like pump is on its way out
Posted 9th May 2016 at 17:38
mocinim
Cheers guys have to take the tank ofc anyway to fit the tank pipes correctly after the previous guy put them in wrong so will change it out then
Will try regulator first
Posted 9th May 2016 at 23:36
sergioiacobucci
Any outcome from this? Did you determine it was fuel pump?
Phase 1 silver track car
335i daily
Posted 17th May 2016 at 15:20
mocinim
Relay the previous guy had been chewing it and stuck it back together with what looked like chewing gum now has a shiny replacement generally performs alot better
Posted 10th Aug 2016 at 15:59
mocinim
Now its fixed
So changed the relay the pump checked all pipe work n wiring
Even swaped over the battery for a new one
Each changed worked a little but the the issue returned
The other week i swapped ovet the cam covers and the inlet manifold cleaned all contacts electrical wiring and gave the injectors a clean and swapped all seals and gaskets
Now she starts first time every time and goes way way better
Netter than the better from before
Lesson learned from this KEEP IT CLEAN Smile
mocinim has attached the following image:
Posted 5th Oct 2016 at 09:06
sergioiacobucci
Air leak then probably?
335i daily
Posted 5th Oct 2016 at 14:00
mocinim
Yep im guessing it was gasket on the inlet was crap and someone previous had left of a support bracket !now replaced!
Posted 5th Oct 2016 at 15:35
