Author Subject: rear brake upgrade
manthos
Can anybody recommend an upgrade for the rear brakes as I have wilwoods on the front and now find that they overpower the rears.
Team SUPERCHARGED
Old Project thread
Posted 6th May 2016 at 22:53
superchargedblack1997gti6
More than likely down to a bad compensator valve rather than needing better rear brakes mate Smile
Posted 6th May 2016 at 23:10
fatlapit
The rears are rubbish
Posted 6th May 2016 at 23:14
Swap to a bias valve instead of the rear compensator and drop some 1144's in the rear - they're cheap in that shape too. Or just try the 1144's first.
Posted 6th May 2016 at 23:24
manthos
Thanks I was thinking about the bias valve and dialing a bit more to the rear. I will try the 1144's what brand are they? or do you have a link?
I think I have heard you can put 205 front calipers on the back but what do you then do about handbrake?
Team SUPERCHARGED
Old Project thread
Posted 6th May 2016 at 23:31
Change your rear pads first Thumbs up
Got Tarox drilled & veined rear discs & Ferodo 3000 pads on rears & can't fault them .....
Also have all new refurbed 330s with Brembos v6 calipers & Ashs bells/rotors on front with Ferodo Ds1.11 pads ....min dust & both still look like new ..these don't overpower my rears Whistle
If everything's working 100% you won't need a bias valve unless you take your ABS off ove course Thumbs up
Posted 7th May 2016 at 06:39
Mintex make the 1144s
Posted 7th May 2016 at 08:09
They're cheap as chips from rally design, about 40 quid IIRC.
Posted 7th May 2016 at 11:52
manthos
Thanks guys.
Team SUPERCHARGED
Old Project thread
Posted 7th May 2016 at 13:24
Rich E Forum Admin
Why? With the temperatures you'll see on the rears they will perform worse than DS2500 pads would for road driving.
DS3000 need to be above 250°C to outperform 2500s, and don't come into their peak performance window until 400°C
Posted 7th May 2016 at 15:47
#BECAUSERACECAR
Posted 7th May 2016 at 16:28
Are you aware Rich that the only time my car goes on the road is to get to Combe x8 times last year or Prescott X1 time last year LOL
They work amazing at Combe & wear rates top end Thumbs up
Posted 7th May 2016 at 23:34
