Author Subject: Supercharger idle?
manthos
I have a low boost charged 6 and it goes perfectly very smooth and fast drives well however I want to know is it meant to be a bit lumpy on tickover sounds as if it has cams in it. Needle does not move stays perfectly still
Team SUPERCHARGED
Old Project thread
Posted 30th Apr 2016 at 16:11
barrym
Do you mean the car feels lumpy/vibrates or the sound out of the exhaust is lumpy/erratic?
My car has developed a lumpy feel and it is down to a knackered lower right engine mount
Black Rallye occassional toy
Posted 30th Apr 2016 at 16:34
manthos
sound, feels fine just sounds like its got cams.
Team SUPERCHARGED
Old Project thread
Posted 30th Apr 2016 at 17:22
sure has cams, they weren't using solenoid valves back then.
Posted 30th Apr 2016 at 18:04
manthos
thanks for the help welshpug........Thumbs down
Team SUPERCHARGED
Old Project thread
Posted 30th Apr 2016 at 18:11
3rd time lucky
Mine is smooth. Sits at 1K for a few seconds, then lowers for a few seconds then up, then down etc but not lumpy. I have a stiff lower mount too.
BLACK RALLYE - Sold
CHERRY RALLYE - new toy
Posted 30th Apr 2016 at 18:09
manthos
mine sits just under 1k contstantly, like 1mm under 0.97
Team SUPERCHARGED
Old Project thread
Posted 30th Apr 2016 at 18:12
They are designed to idle higher than normal. Around 1k is spot on but no it shouldn't sound any different ticking over than normal really.
Posted 1st May 2016 at 09:56
rich_w
Idle speed is increased on the ECU software to around 1000, depending on what version of the software you have.
Idle should be smooth, could be a number of reasons for it not being. Lambda is probably the first thing to try. If you unplug it and it's no different, that may be why.
Can be lots of other things though.
Contact Details:
07732 822546
Posted 1st May 2016 at 13:36
manthos
Ok Thanks Rich I will start with Lamda
Team SUPERCHARGED
Old Project thread
Posted 1st May 2016 at 14:05
I put a new NGK lambda on there and changed the plugs mate
Posted 1st May 2016 at 14:42
manthos
In that case any ideas? Rich?
Team SUPERCHARGED
Old Project thread
Posted 1st May 2016 at 15:51
RetroPug
Definitely the correct part no. for the lambda? Seem to remember something about gtis not liking anything other than Bosch but no idea if that is the same for charged cars.
Posted 1st May 2016 at 17:07
Yeah deffo a correct one and they are great lambdas,just as if not better than bosch
Posted 1st May 2016 at 17:42
rich_w
We've found the NTK lambdas not to be that great, we always fit Bosch LS3717 as they seem more responsive and last longer, particularly on the SC engines which run higher EGTs than standard motors.
The best bet is to put it on diagnostics. It won't show any codes, by looking at the live running data you should be able to see if you have any lazy or dodgy sensors.
I wouldn't worry about it too much if it drives fine. Cam timing and exhaust system can also effect how it behaves at idle.
Contact Details:
07732 822546
Posted 1st May 2016 at 19:06
manthos
Drives fine Rich, very very rarely of you have driven it for about 10 miles, turn it off. get back in turn it on it will start then die straight away, as if it just didn't catch the revs as they dipped (icv) however the icv seems absolutely fine other than that and as said needle doesn't fluctuates. turn it back on and it's fine as if it didn't happen
Team SUPERCHARGED
Old Project thread
Posted 1st May 2016 at 19:12
When it was rolling roaded tester said it's was ill fine afr wise so I can't see the lambda being an issue
Posted 8th May 2016 at 23:06
manthos
nah the idle is all good. just sounds like it's got cams. I can live with that sounds good. haha
HOWEVER..... Once the ar is up to temperature after you have driven a little if you then turn it off for example you pull up to put some fuel in, when you come to turn it back on again it dies. always turns on from cold fine everytime. Once warm it will turn on and as revs drop immediately die
Team SUPERCHARGED
Old Project thread
Posted 8th May 2016 at 23:11
