Author Subject: gear stick/linage bushes
barrym
Hi all,
my gearstick rattles at times and has a little too much play so have ordered the 2 bushes that connect the stick to the linkage.
My question is: can they be fitted from inside the car by removing the stick and associated gubbins or do I have to get under the car and remove one of the exhaust heatshields?
I have just bought a new Jetex system so will be getting under the car anyway, but if I don't have to try and remove (more importantly try and refit) a heatshield then so much the better.
Thanks for reading and hope you can help Thumbs up
Barry
Black Rallye occassional toy
Posted 20th Apr 2016 at 14:45
mocinim
From the underside mate do you have quick shift linkages if so this is most likely the the rattle cause put grease in the nuckles if this is the case
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 20th Apr 2016 at 14:50
barrym
Hi mate
No quick shift or fancy gear linkages. Pretty sure it is these bushes as if I just rest my hand on the gearstick the rattle disapears.
Balls, was really hoping not to have to disturb the heatshields.
Thanks bud
Posted 20th Apr 2016 at 15:00
barrym
Just to clarify, if I have to do this from under the car does it definately involve removing one of the heatshields?
Posted 20th Apr 2016 at 17:22
cully
yes and maybe the exhaust Wink
Posted 20th Apr 2016 at 20:06
mocinim
As cully said
The fixings if not already broken away will break off re secure the shield with same large dia self tappers with hex heads youll need to drill small holes to fit best blob a bit of paint or primer in the little holes before screwing to help tame future rot the shields overkap each other so best to ge the hole car up for access
Posted 20th Apr 2016 at 20:39
mocinim
Best get some shiny shields ready
mocinim has attached the following image:
Posted 20th Apr 2016 at 20:43
barrym
Cheers guys.
mocinim they look the nuts mate!
cully the exhaust will be off anyway as it's getting replaced.
will get some hex head self tappers ordered. Any idea on size? Should I get some penny washers to go with them?
Thanks again
Posted 21st Apr 2016 at 17:36
sod bashing tek screws into the floor!
Posted 21st Apr 2016 at 18:12
barrym
Ok so what are you saying? Presumably get the right fixings from peugeot and drillout the old fasteners?
Posted 21st Apr 2016 at 18:28
mocinim
Not tec screws your not fitting a roof if you require something fancier use rivits i predlfer 1/4 inch fat tappers 8dia with a washer
Fits well looks nice keeps it secure choices sre many
Posted 21st Apr 2016 at 23:16
