Author Subject: Engine knock when hot?
djb
Hello all,
I'm getting a small amount of engine ping when my engine has reached its hottest temperatures between 90-97 degrees.
As is typical with engine ping, it only occurs at low rpm, normally when I'm starting on a hill.
Fuel octane I'm using is between 95-98 octane.
What could be causing it? Hotspots? I'm assuming the knock sensor is working because I have no codes for it.
Posted 6th Apr 2016 at 02:44
aaron6
I would say that's pretty normal. They all pink a little under load on a hill from what I've seen.
Posted 6th Apr 2016 at 06:16
djb
Cheers Aaron, yes I've been reading about it just now and there are a lot of people saying it's affecting their cars so it must be pretty standard. Especially here in Aus where it's hot as hell atm.
I wonder if you can swap out the stock radiator for something that's actually decent.
Posted 6th Apr 2016 at 07:51
aaron6
Rig your fans to run from the air con button too unless the air con actually works that is. You could check that the plugs are okay too.
Posted 6th Apr 2016 at 11:50
never had knocking from mine?!
Posted 6th Apr 2016 at 12:04
aaron6
Pinking. Not ever?
Posted 6th Apr 2016 at 13:16
cully
mine dont pink or knock!
Posted 6th Apr 2016 at 14:03
Ben_W
Formerly gpm
They shouldn't pink or knock. I thought they had anti knock sensors to.prevent this?
Posted 6th Apr 2016 at 15:23
Yep, if it's knocking/pinking something isn't right.
Posted 6th Apr 2016 at 15:31
mocinim
Try some different oils see if it stops
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 6th Apr 2016 at 15:33
oil will not stop it.
Posted 6th Apr 2016 at 15:38
mocinim
Whats likely to cause it Mei
Posted 6th Apr 2016 at 15:59
cully
heat, fueling, timing, carbon build up
Posted 6th Apr 2016 at 20:00
Mine does a bit on 95 octane fuel
Posted 6th Apr 2016 at 20:11
mocinim
So what in the engine is actually making the ping whats contacting what is it block expansing trapping pistons worn bearings loose shafts etc etc ???
Posted 6th Apr 2016 at 21:17
It's the fuel/air mix ignighting before it should, which is bad news.
Posted 6th Apr 2016 at 22:51
pete_rallye
Never known one to pink either! If it's really hot you can try running hotter plugs (or check yours are in good nick) but I would suspect something else is amiss, check fuel pressure, compression and leak down if you have the gear. If they are all ok it could be a dodgy lambda running the engine leaner than it should be, get a garage to check your emissions and make sure its somewhere near what it should be.
Lap of the 'ring
Posted 6th Apr 2016 at 23:04
djb
How easy is fuel pressure to test if I have my own gauge?
Posted 7th Apr 2016 at 06:04
cully
this! Thumbs up
Posted 7th Apr 2016 at 06:28
djb
Just an update, I filled up with 98 instead of 95 and so far I haven't heard it ping yet. It must be the s**t Aussie fuels.
Posted 8th Apr 2016 at 09:53
mik
On a hot day pinking is more likely, and you have a few of those up in Queensland. Higher octane fuel is a good idea in that case.
Cherry Rallye SOLD
Posted 8th Apr 2016 at 14:57
