Author Subject: Rev Counter Needle
RetroPug
I have finally fixed my non-working rev counter, a replacement instrument cluster has sorted it.
Out of the two rev counters I could have put in the cluster, one was just broken, and one works but the needle returns to below 0 and doesn't have any resistance that makes it stop at 0 as it should. This causes it to under read by a couple of hundred.
Basically my question is: can I fix this or do I need to get another rev counter and put it in this instrument cluster?
Picture:
Posted 3rd Apr 2016 at 10:56
i have got about 3 sets of clocks in bits here
the needles can simply be wound anticlockwise and clockwise until you hit resistance, which is the start of the sweep. i had to graft the HDI face onto some GTi6 clocks the other day cos my whole cluster packed up. you will be fine to just adjust the needle. once you take the face off and can access the needle, you will see what i mean about being able to push it back and forward. you basically ant to get it so the resistance causes the needle to fall at 0, rather than -5 or whatever it's at now
mine wasn't right and i had it out about 4 times making minor alterations to the needle positions
Posted 3rd Apr 2016 at 12:59
6waysforward
Or pull the needle of and place it at 0.
Fitting is the reverse of removal Thumbs up
Posted 3rd Apr 2016 at 19:59
RetroPug
I'll give this a go when I've got some time. There's doesn't appear to be resistance anywhere in the sweep though.
Thanks guys.
Posted 5th Apr 2016 at 21:04
