I am looking for a check strap for the passenger door of my Gti6, anyone from here has one they are willing to part with?
Cheers.
| Author | Subject: Passenger side door check strap |
ben1024
Newbie Location: Bristol Registered: 21 May 2014 Posts: 17 Status: Offline |
Hi, I am looking for a check strap for the passenger door of my Gti6, anyone from here has one they are willing to part with? Cheers. |
jord294
Still available from maindealer________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
mik
Seasoned Pro Location: Kent Registered: 17 Feb 2011 Posts: 2,100 Status: Offline |
Check (see what I did there) if you need the whole check strap or just a pin. There are two types depending on the age of the car. One is an entire check strap with the pivoting part a rivet, the other is a two piece version held together with a roll pin. The roll pins do break eventually. I thought I needed the entire chec kstrap as it looked as though it was missing, but it turned out it had retracted itself into the door. I extended it, tapped into place a new roll pin from the dealer, job done! ________________________________________ Cherry Rallye SOLD |
ben1024
Cheers for the advice, the strap is still in one piece I think it either has some play on the pin or has cracked slightly (which is what happened to my 406 coupe strap). I checked the bolts and they are tight, the problem I have is the common knock that the door does when you open it. I thought it would be easier to change the whole thing but I will have a closer look tonight at the car to see whether I need to change only the pin or the whole thing |
probably just the pin needs changing9181 63 DOOR STRUT PIN can't remember if the later type has a roll pin or a solid steel pin. theyre £3 odd, so I'd be measuring and seeing if I could get an alternative, or replacing the whole checkstrap assembly. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
alcon
Senior User Location: Glasgow Registered: 19 Jan 2005 Posts: 941 Status: Offline |
I replaced both my door stays last year and they cost £66.77 from the main dealer. Quite expensive but made a massive difference to the opening and closing of the doors...ie no clunking anymore!________________________________________ 1999 GTi-6 (china blue)1999 Rallye (black) |
