Author Subject: auto wiper problem
sageman
well all the little LEDs were doing was blinking rapidly i decided to get a 'working' one off ebay but this seems to have the same problem
if i shine a torch into the detector it shuts the wipers off but as soon as i remove the torch it (detects) rain and starts the wipers again (flashing as the wipers move) but as soon as he wipers come to a stop it carries on blinking like the sensor hasnt picked up the LEDs from the unit
(it works by detecting the brightness of the LEDs going down as raindrops refract some of the light away)
yes ive tried without the torch if you were wondering
any ideas
1976 Reliant Kitten
1985 Reliant Fox Tandy campervan
1998 GTI-6
1993 Citroen XM sei V6 (barn find)
Posted 11th Mar 2016 at 20:39
mocinim
So to clarify you changed the rain sensor on the wind screen ?
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 9th Mar 2016 at 22:55
sageman
yes i did
1976 Reliant Kitten
1998 GTI-6
Posted 10th Mar 2016 at 02:59
sageman
anyone have any ideas please
1976 Reliant Kitten
1998 GTI-6
Posted 11th Mar 2016 at 20:36
sageman
nobody??
1976 Reliant Kitten
1998 GTI-6
Posted 19th Mar 2016 at 00:37
RetroPug
Could this possibly be a relay issue?
Posted 19th Mar 2016 at 11:11
cully
id go for relay too Wink
Posted 19th Mar 2016 at 11:22
sageman
if it was relay wouldent there be problems operating the wipers in the other stalk positions
unless two relays
but when in auto the wipers just act like normal intermitent ones
1976 Reliant Kitten
1998 GTI-6
Posted 19th Mar 2016 at 11:57
cully
there are two relays Wink
Posted 20th Mar 2016 at 11:13
ahhh, thats why the phase 2.5 loom made no sense to me in adam's xsi LOL
Posted 20th Mar 2016 at 11:21
sageman
well if i unplug either purple relay they stop working altogether
if i swap them around there is no change
am i right in saying these are switching relays how do i test that they can switch propally
im starting to think the replacement unit is buggered too
1976 Reliant Kitten
1998 GTI-6
Posted 20th Mar 2016 at 12:16
cully
can you get slow speed and fast speed? if you can the relay on the left is working
swap the relays can you get slow and fast speed? if yes both relays work
if so the sensor is probably shot the flashing led normally should be lit constant on a working unit
Posted 20th Mar 2016 at 12:30
sageman
right seems the "tested working" sensor is shot then bugger
1976 Reliant Kitten
1998 GTI-6
Posted 20th Mar 2016 at 13:12
scotzman
Just a thought, I have no idea if would actually have any effect, is the wiper stalk from an auto wiper car or has it been replaced with a standard stalk?
Posted 20th Mar 2016 at 15:42
pug_306
Ive probably got a good rain sensor buddy, im only in Thetford
1992 205 GTi6
205 Turbo 340bhp
Posted 20th Mar 2016 at 17:39
fast_eddie
I had perfectly working wipers and sensor until my motor failed because I hadn't unblocked the water drain beneath it. I changed the motor for a second hand unit and ever since then, the wipers have a mind of their own on AUTO.
Every other setting is fine.
Maybe your motor is dodgy like my second hand one?
Posted 24th Mar 2016 at 00:32
