displaying posts 26 to 50 of 50
Pages (2): 1 [2]
Author Subject: My 6 Car Fire
How are people connecting to Th two hoses on the tank ....the push fit 8mm ones ?
No room to fit anything I've seen ?
Posted 1st Mar 2016 at 04:25
I tried the 5/16" connectors that torques sell to connect my lines to the push fit connectors, that was a failure. In the end i just jubilee clipped them on and hope for the best.
I think others have bought some sort of barbed adapter that pushes into the old hard plastic pipe.
Posted 1st Mar 2016 at 17:03
What onto these ?
PS this is a spare not from my car LOL
Posted 1st Mar 2016 at 17:29
Like this that pushes into the original plastic Fuel line ?
Posted 1st Mar 2016 at 17:55
What onto these ?
Yeah, that was my plan, to fit one of these onto the fuel pump push on fittings.
http://www.ebay.co.uk/itm/AN-6-6AN-JIC-AN-06-Quick-Connect-5-16-Female-Fuel-Line-Rail-Adapter-BLACK-/170764095506?hash=item27c2555012:m:mHHZVaJ0qfpUykulnwmRXHA
I've not seen what others have used to push into the original hard fuel line so i can't comment on that.
Posted 1st Mar 2016 at 18:03
cully
as above use quick connects to connect to the pump housings
as for the plastic hardlines it took me a while to work out how to connect to it without chrushing it or using barb fittings
http://306oc.co.uk/forum/showthread.php?tid=13188&pid=573762#pid573762
but im using
plastic hard-line > 6mm Pipe inserts > 8mm compression hard line to AN6 adapter
things to watch though
the compression olives are tight to get over the plastic hard line,
the 6mm inserts will need the front leading edge filed so they enter the plastic pipe without digging in ,they are tight entering the olive once inside the pipe,
Posted 1st Mar 2016 at 18:22
Looks brilliant Paul where did you buy them from ?
Also in link ...Did you weld JIC6 onto fuel rails 8 and 10mm ?
Posted 1st Mar 2016 at 18:37
cully
the shopping list is here
http://306oc.co.uk/forum/showthread.php?tid=13188&pid=575171#pid575171
yes they are the same size just drilled to take the different size for flow and return on the rails, then silver soldered onto the rail
all the parts came from evilbay Wink
Posted 1st Mar 2016 at 18:48
prism7guy wrote:
What onto these ?
Did you say you tried these ?....this was a failure
N -6 (-6AN JIC AN-06) Quick Connect 5/16" Female Fuel Line / Rail Adapter BLACK
cully
Post #35
you get the idea.....
Posted 1st Mar 2016 at 18:51
Post #36
Day666 wrote:
prism7guy wrote:
What onto these ?
Yeah i tried them, not enough space for the barb to catch and hold them in place.
Posted 1st Mar 2016 at 18:57
marksorrento205
Post #37
I used some 9/16 male blanks that cost £1.50 each. They were hex ones so you can use a spanner on both the fitting and the welded part of the fuel rail. Just drilled them out to suit.
Posted 1st Mar 2016 at 19:48
Post #38
Where did you get yours from Cully ....the Fuel tank olive ones & your Fuel rail ones ?
Posted 1st Mar 2016 at 20:13
Post #39
Mark where did you get your £1.50 Hex ones ?
Posted 1st Mar 2016 at 20:15
cully
Post #40
all the bits came from ebay
i have only replaced my engine bay lines to the iner wing hardlines not the whole system
i cant get on ebay here at work, i will find the sellers once home
Posted 1st Mar 2016 at 20:21
Post #41
i cant get on ebay here at work, i will find the sellers once home[/quote
Please Thumbs up
I need the fuel sender pipe ones with inserts & olives ASAP m8
Posted 1st Mar 2016 at 22:08
cully
Post #42
i haven't connected to the fuel pump at all
i believe they are called quick connects the ones that go onto filter housings and the pump
Posted 1st Mar 2016 at 22:13
orta
Post #43
Glad to hear you and car are ok
CLUB BLACK RALLYE
||B8s||60-70mm drop||Black Partner Steels||P1 VTS Rack||Refurbed Beam||Hybrid ARB||VTS Torsion Bar||
Posted 1st Mar 2016 at 23:00
Post #44
my car is older so its normal flexI hose at the pump end onto 8mm hard line.
compression fittings in the engine bay to -6 hose.
Posted 1st Mar 2016 at 23:07
cully
Post #45
Ebay item 301210932829 AN6 MALE to 5/16" (8mm) HARDLINE HARD LINE ADAPTER
Ebay item 271143300843 Nylon/Polyurethane Internal Tubing Metric Pipe Insert (6mm ID)
Ebay item 301720536683 Weld On Fitting AN6 Male Steel
ebay user hosefittingsuk is very good over the phone he will beat his online price of ebay and you can pay card over the phone Wink
Posted 1st Mar 2016 at 23:49
Post #46
Thank you Tom Thumbs up
Posted 2nd Mar 2016 at 07:19
Post #47
Your a bloody Legend Cully Thumbs up
Thank you so so much m8
Posted 2nd Mar 2016 at 11:34
Post #48
I think it might be best to leave them be & come off 4-6inchs with Olive fittings ?
Posted 2nd Mar 2016 at 07:24
Post #49
Only problem is Cully this is all from Three separate sellers m8 LOL
Non of them Hosefittingsuk m8 ?
Posted 2nd Mar 2016 at 11:35
cully
Post #50
yes i know
i bought my ptfe braided and ptfe fittings from Hosefittinguk
the rest was got from other sellers free postage and cheaper than torques + shipping
Posted 2nd Mar 2016 at 11:51
Pages (2): 1 [2]
