Rallye Race Car
| Author | Subject: Oil temperature sensor thread size |
demondriverdan
Anyone know what the thread size is for the oil temp sensor in the sump? Not sure how to wire up the existing one with my data logger so want to get a replacement. ________________________________________ Rallye Race Car |
14x1.25 or 16x1.5.easy to wire up, single wire from the dash, earth is body of the sender same as coolant temp. not usually the same resistance range as the aftermarket gauges though ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
demondriverdan
From looking at the manual of my data logger (Race Technology DL1 Clu I might need a resistor but no idea what size to get the right values? ________________________________________ Rallye Race Car |
demondriverdan
Any idea whether mine would be an M14 or M16? Need to get a thread adapter to work with the aftermarket sensor.________________________________________ Rallye Race Car |
demondriverdan
Failing that, is it a Bosch sensor? Found some info that they need a 1000ohm resistor to work properly________________________________________ Rallye Race Car |
1131 A6NFP 01 TEMPERATURE SENDING UNIT 14X125 165 DEG BE- - BLUE I believe its a Jaeger unit. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
demondriverdan
That's a pain. I'm not sure how to find out what resistor it needs to get the right values.________________________________________ Rallye Race Car |
check its resistance across a few temperatures, and compare it with what resistances you need.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
