| Author | Subject: Russain Guy top mounts coloured |
Just had my Top adjustable mounts Anodised ...ready for the front dampers end of next week Day666 has attached the following image: |
mocinim
Seasoned Pro Location: The Darkside of bedford :) Registered: 09 Jan 2015 Posts: 2,307 Status: Offline |
Very nice very shiny ![]() ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
Won't be for long Bit Sad really but only had it done to stop corrosion long term |
mocinim
Should hold out for a while longer in any case and its a good feeling fitting shiny bits seems so much more worth while________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
mocinim
mocinim wrote: Should hold out for a while longer in any case and its a good feeling fitting shiny bits seems so much more worth while My latest effort white !! (dont know dont ask) mocinim has attached the following image: ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
Chr1sch
Seasoned Pro Location: Worcester Registered: 02 Aug 2014 Posts: 1,025 Status: Offline |
Nice! I take it you are cutting larger holes in the turrets then? - I'm assuming there is no point with adjustable top mounts without coilovers? (i.e. B8's?) |
Capt Pedantic Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,868 Status: Offline |
not enough room to move a standard spring around.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
welshpug! wrote: not enough room to move a standard spring around. As Welshpug said can't & no point ...yes have to cut & also use 15mm front wheel spacers with longer stud conversion as per Russain Guy has ...because Coilovers dampers are threaded down nearly to Droplink ARB bracket ..v long Eibach Coilovers springs with Progressive springs fitted as well & tires touch the springs otherwise .. |
mocinim wrote: mocinim wrote: Should hold out for a while longer in any case and its a good feeling fitting shiny bits seems so much more worth while My latest effort white !! (dont know dont ask) Whites a great colour .....that's all you will have soon sadly ...a photo of how it did look ......nice job though |
mocinim
Day666 wrote: mocinim wrote: mocinim wrote: Should hold out for a while longer in any case and its a good feeling fitting shiny bits seems so much more worth while My latest effort white !! (dont know dont ask) Whites a great colour .....that's all you will have soon sadly ...a photo of how it did look ......nice job though Cheers sub frame arb are also in white the car is not for regular use dry days only probably pugfest and other days out The astor maybe my car for daily or track or both ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
