How do you remove the coil packs? or do i need to remove the brake fluid reservoir?
| Author | Subject: coil pack removal |
shabusta
Regular Location: Australia Registered: 10 Sep 2015 Posts: 244 Status: Offline |
rikky
should be able to just rock engine forward enough to get access to the coilpack cover bolt________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
alcon
Senior User Location: Glasgow Registered: 19 Jan 2005 Posts: 941 Status: Offline |
or use an Allen key bit in combination with a ratchet spanner or open ended spanner. A bit of a faff but can be done easily enough________________________________________ 1999 GTi-6 (china blue)1999 Rallye (black) |
shabusta
All bolts removed from the cover, yes the bolt under it was a right belend, but now i cant get the cover past the metal part of the resovoir without possibly (?) Damaging the coils. |
alcon
Cover should get past the master cylinder without having to remove it. XSi engine looks slightly different but should still wiggle off to reveal coil packs.________________________________________ 1999 GTi-6 (china blue)1999 Rallye (black) |
shabusta
after fiddling some more.... i have to remove the strut brace? |
demondriverdan
Probably, yea. I remember having the same problem before which is why I don't bother running a cover anymore.________________________________________ Rallye Race Car |
stan_306gti6
You will need to remove the strut brace, yes.________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Isn't xsi 1 twin coil running wasted spark joined all together? But yes remove the strut brace first or no chance on an xsi.________________________________________ Black power baby! SUUUUUPERCHARGED Seat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
jimmyhackers
Seasoned Pro Location: birmingham Registered: 14 Jun 2011 Posts: 1,302 Status: Offline |
i have an xsi.... tis more fiddly than the gti as the coil packs are built into the cover....but it can be done without removing athinythign else. tis quite fiddly to wrangle off and even fidd;lierr to wrangle back on but not undoable ________________________________________ the world is changed by people in sheds |
