Author Subject: still not hitting proper temps when moving
jimmyhackers
with much annoyance my xsi still doesnt want to sit at 90 degrees : s
it was an aircon with a double fan, now its a single fan, with the air con condenser rad removed (more flow to original water radiator).
on my drive left running the car with get upto 90 and sit there fine. the heater matrix is blowing hot again at the 90degreees so that problems dissapeared. (it use to blow cold when engine was hot)
but as soon as i start moving about (driving) the needle goes down to 75ish degrees.
i asked before on here a while ago if there was a different thermostat for the non aircon (single fan)models but got told no...
so.....im unsure what to do, the only thing i can think to do is put a peice of cardboard infront of the half of the radiator where i have removed the fan.
to vaguely simulate the air flow ristriction that the old air con condensor rad used to provide?
any other ideas?
Posted 16th Jan 2016 at 12:36
scotzman
Every one I have had sits about 77-79 during normal driving including my current car which has a new genuine thermostat fitted so yours doesn't seem too far off.
Posted 16th Jan 2016 at 12:53
Mine sits around 80 when driving about so I wouldn't worry too much.
Posted 16th Jan 2016 at 13:23
mocinim
My rallye will sit at 90° at standing but runs at 75° and the astor just a little hotter on run sounds good to me does your xsi have oil temp guage if so whats it saying in comparison
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 16th Jan 2016 at 14:01
fatlapit
How accurate do you think the guages are??
Posted 16th Jan 2016 at 14:15
barrym
My rallye sits at about 78 on a run. But it used to appear to sit at 83 until I had to change a faulty temp sensor. I am perfectly happy with this.
My oil temp sits at 90 once warmed and only varies a little even when the engine goes over 100 in traffic.
If i left my car idling with no airflow the temp would keep going up till the fan kicked in. It is a live gauge so shows actual temp not just sits at 90 like more modern cars
Black Rallye occassional toy
Posted 16th Jan 2016 at 14:23
mocinim
There 101% all the time thought you would of known that bud Smile
Posted 16th Jan 2016 at 16:32
jimmyhackers
ok.... it was my understanding that the correct fuel ratio wasnt "activated" untill the engine was upto a certain temp (this temp being 90 degrees c)
i worry as my exhaust smells a little rich (nearly didnt pas mot emmisssion) and im contemplating an overfueling ratio due to this "problem"
can anyone confirm at what temp the enginne managment switches over to it "lean" mixture
Posted 16th Jan 2016 at 17:20
jimmyhackers
going through my old posts i found this one left "unsolved"
i ended up cutting out a peice of foam to block off the empty space in the shroud where my 2nd fan was removed.
this raised the running/moving temp to around 81-82 (normal) and she never really got above 90/95 in traffic/standstill
i figure this also increased the fans airflow/pressure through the rad, as there isnt a whacking great hole in the shroud. Smile
Posted 18th May 2024 at 15:32
