Author Subject: Soft Unlocking
To use an alternative set of keys, do I just disconnect the battery while the ignition is on then reconnect and use the new keys?
Posted 15th Jan 2016 at 01:01
No just take the chip out of the key and put it in the new key ?
Depends what you mean by use a different key ? Are you changing the ignition barrel ?
Posted 15th Jan 2016 at 07:43
Yes, I'm changing all the locks and ignition barrel.
Do I just turn the ignition on, remove the battery, remove the key, insert the new key, then reconnect the battery to code the ECU to the new key?
Posted 15th Jan 2016 at 08:01
cully
you will not code the new key to the ecu without software/hardware to program it
Posted 15th Jan 2016 at 08:28
mocinim
Cully ! Is this still the case with an unlocked ecu cheers Smile
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 15th Jan 2016 at 08:59
mocinim
pug_306
If its a properly unlocked ecu it will be plug and play. If its soft unlocked you need to unplug your transponder
1992 205 GTi6
205 Turbo 340bhp
Posted 15th Jan 2016 at 09:53
cully
if the ecu is unlocked why would you need to program a key?
if you are only changing the lock set only not the ecu
I would just change the new key blade into your old fob housing
Posted 15th Jan 2016 at 10:12
I was under the impression that once the ECU was soft unlocked it would lock using the new chip in the key?
I only had one old key but have two new ones so thought this would be the easiest and cheapest way to do it.
Posted 16th Jan 2016 at 02:50
cully
to soft unlock ecu
disconnet ecu with engine running then cut the transponder wires, the 3 wire numbers are 820,821,822
by cutting the wires the immo decoder cant send the lock unlock code to the ECU
this will bypass the immo chip so you have no ecu security there is a risk the ecu will re-lock on its own,
this wont help getting the second key working with the central locking that is a different issue
if you have i working key with working immo
just get the immo chip cloned at a good locksmiths and insert it into the 2nd key case
Posted 16th Jan 2016 at 09:34
