I have searched and the normal issues are with the lights, boot seal, rear windows. I have checked and round the lights, window/boot seal all looks dry. Any other places to check?
Ben_W
Formerly gpm Location: Lutterworth Registered: 01 Sep 2007 Posts: 2,941 Status: Offline |
Has it had a CD changer at some point? Are there holes drilled for the mounting bracket?________________________________________ Cherry Red Rallye .... On going OEM spec restoChina Blue GTi6 .... Weekend toy Black 208 GTi .... Wife's car now Silver BMW 550i.... The executive missile |
RetroPug
Do you have an arch liner fitted?If not, then check the c-pillar for corrosion/lack of c-pillar behind the trim. ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
Kenan
Regular Location: Exmouth Registered: 20 Oct 2013 Posts: 307 Status: Offline |
No idea if it had a cd changer or if there is an arch liner, but both things to check and I will report back.Thanks Guys |
Kenan
Right no signs of a cd changer and arch liners look present and correct.The carpet is bonded to the back of the arch so seems a shame to pull it off. The plastic moldings on the c-pillar under the window are they easy to get out? |
Ben_W
Hmmmmmmmm, I suspect it's either going to be the boot or light seal________________________________________ Cherry Red Rallye .... On going OEM spec restoChina Blue GTi6 .... Weekend toy Black 208 GTi .... Wife's car now Silver BMW 550i.... The executive missile |
mik
Seasoned Pro Location: Kent Registered: 17 Feb 2011 Posts: 2,100 Status: Offline |
Always worth pulling out and resealing the lights, and spraying the boot seal with silicone to make it nice and supple.________________________________________ Cherry Rallye SOLD |
jimmyhackers
Seasoned Pro Location: birmingham Registered: 14 Jun 2011 Posts: 1,302 Status: Offline |
its not the rubber bung(cable guard) at the top of the boot lid connecting the two?sometimes these can perish or pop themselves out. ________________________________________ the world is changed by people in sheds |
thewho07
Regular Location: Scotland Registered: 11 Aug 2009 Posts: 289 Status: Offline |
I had this problem it was down to corrosion in the wheel arch. It had pitted quite baddly and left pin holes where water could get through. Pull back the carpet and see, it'll glue back on easily enough. Have a look at my project thread there's a picture of how bad the arches were. |
Cherry Buell
Newbie Location: Cork Registered: 06 Mar 2015 Posts: 33 Status: Offline |
thewho07 wrote: I had this problem it was down to corrosion in the wheel arch. It had pitted quite baddly and left pin holes where water could get through. Pull back the carpet and see, it'll glue back on easily enough. Have a look at my project thread there's a picture of how bad the arches were. I'd have to second this had the same problem with a phase 3 dturbo that spent one too many winters in Scotland. Pull out the arch liner and have a good look up there. If there is surface rust you could try Fe 123 and an epoxy mastic paint over. You'll be needing the correct width fir tree push clips to put the liner back in. I've also seen a lad wet his own boot by shooting a jet hose up to the spare wheel (wheel lock missing). |
Kenan
Yeah pulled the archh liner off and all looks good. Pulled out the rear lights and they were very dirty round the seal, so have cleaned them up and the boot seal. Just need to wait for some rain and see how it goes. |
Kenan
Nope still wet, almost seems to be after I have opened the boot. Will try the rear window seals next. |
anth
Put the rear seats down and take the parcel shelf out. Run the hose over the car and it may show where it's coming from.It could be anywhere. |
mocinim
Seasoned Pro Location: The Darkside of bedford :) Registered: 09 Jan 2015 Posts: 2,307 Status: Offline |
anth wrote: Put the rear seats down and take the parcel shelf out. Run the hose over the car and it may show where it's coming from. It could be anywhere. If your still at a loss after that check the water pipe in the roof not likely but not impossible ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
Kenan
mocinim wrote: If your still at a loss after that check the water pipe in the roof not likely but not impossible It's not this as I don't use the rear water much and the car gets wet when stood (or at least I don't think it is) |
Kenan
anth wrote: Put the rear seats down and take the parcel shelf out. Run the hose over the car and it may show where it's coming from. It could be anywhere. This will be next on the list after the rear windows. The water is coming out from the plastic where the parcel shelf speaker connector goes. And Happy Birthday |
mocinim
Dont use my rallye rear water much eigther mate but my one way valve is bolloxed and it leaks down the back window when i travel about if your pipe is damaged could be leaking by itself without activating your pump Like i said not likely but not impossible ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
