Author Subject: Peter T Re profiled Kent Pt81's
p1234
I have a set of Re profiled Kent Pt 81's,
The inlet was reprofiled by Peter T last year to the following:
advertised duration 272 deg.
duration @ 0.050" 230 deg.
max lift 0.410
They did about 100 miles before I went with a supercharged engine and used standard cams
£350 including postage worldwide
p1234 has attached the following image:
Posted 3rd Jan 2016 at 15:34
p1234
Will take £320 for these, absolutely perfect, bought from Miles @ PugRacing
Posted 8th Jan 2016 at 17:21
walker_texasranger
What are they mate? Re profiled standard cams to PT81 spec??
Hilux InvincibleX daily
306 No.13 Doh
Posted 9th Jan 2016 at 11:29
I doubt it as you can't do that I think they are re profiled pt81
Posted 9th Jan 2016 at 12:34
standard cams can be re-profiled.
these are Kent cams with a further modified inlet profile.
Posted 9th Jan 2016 at 13:10
p1234
Its difficult to get a decent photo of the stamps on them but WelshPug is correct, these are a set of Kent Pt81's. The inlet was sent to Peter T who re-profiled it to the specs listed above.
These would definitely need a deeper pocket in the piston cut out to avoid bending valves.
These made excellent power when fitted to a pretty much standard engine on throttle bodies.
Posted 9th Jan 2016 at 16:36
IvayloPavlov
What the lift at TDC is?
Posted 9th Jan 2016 at 22:27
I know that dude I meant you can't reprofile std cams to pt81 spec
Posted 14th Jan 2016 at 18:39
miles
you can re-profile any cam to any spec, Just takes a little work
www.pugracing.com
Posted 14th Jan 2016 at 19:11
walker_texasranger
I've seen a couple of sets on here that have been re profiled to PT81 spec, by Peter T if I remember correctly Smile
306 No.13 Doh
Posted 14th Jan 2016 at 22:26
