Author Subject: steering rack
mocinim
Hi guys due to replace my inner tie rods on the rallye have a spare rack was checking ovr how to go about it how do i remove theouter rubber piece do i have to dismantle the ram e.g remove bolts thought it was an easier process than this any advice would be appreciated
Cheers ?
mocinim has attached the following image:
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 20th Dec 2015 at 18:46
mocinim
mocinim wrote:
Hi guys due to replace my inner tie rods on the rallye have a spare rack was checking ovr how to go about it how do i remove the outer rubber piece (blue arrow) do i have to dismantle the ram e.g remove bolts (RED ARROWS) thought it was an easier process than this any advice would be appreciated
Cheers ?
Posted 20th Dec 2015 at 19:02
no need to remove the ram, the left boot has a steel ring bonded into its inner end, just lever it off carefully.
Posted 20th Dec 2015 at 19:36
mocinim
This bonded ring is it accessible from under the gator
E.g undo clip move gator to get access to the steel ring remve carefully then pull of left rubber (BLUE ARROW)
Posted 20th Dec 2015 at 20:12
the steel ring is part of the boot.
Posted 20th Dec 2015 at 20:19
mocinim
Cheers welshpug once again much appreciated mate
Posted 20th Dec 2015 at 22:10
mocinim
Hi gents back again how do i remove the inner gator have the rack out but before i dismantle it would be good to know the correct way do i need to remove the ram ? And how does the gold ring come off
Posted 5th Jan 2016 at 20:55
eddy_gti6
Do you have to buy them boots from Peugeot or should any motor factors sell them?
Posted 5th Jan 2016 at 21:03
mocinim
Got mine on the bay mine is peugeot original but fubi do them on the bay aswell any idea how ti get them off
Posted 5th Jan 2016 at 21:16
eddy_gti6
Stanley knife Wink
Posted 5th Jan 2016 at 21:17
mocinim
Sorry did you mean the outer rubber boot or the inner gator
mocinim
eddy_gti6 wrote:
Stanley knife Wink
Ok any idea on how to get a new one on Wink
Posted 5th Jan 2016 at 21:18
cully
if you tare the packet, pull it out the pack, you should be able to roll it down your shaft
Big grin
Posted 5th Jan 2016 at 21:59
mocinim
NO !! Didnt come in a packet cant just be slid on !!!!!????
Posted 5th Jan 2016 at 22:46
mocinim
Hi gents back once again when refitting the steering rack what the best method to align the steering wheel and ram movement cheers Smile
Posted 6th Jan 2016 at 21:33
mocinim
No one know !!!!
Posted 8th Jan 2016 at 22:35
Denis
The way I did it couple of times:
- Undo the RAM from the rack to get full movement left/right (Gti/Rallye RAM limits the movement when turning right)
- Turn the rack one way fully and measure how much it comes out
- Move it the other way and measure again on the same side
- Add up the measurements and divide by two to find out what is the mid-point
- Move the rack so that it is at the mid-point
- Fit the steering wheel straight
- Re-attach the RAM
Cherry Red Rallye Project thread
WhiteBMW M140i
Posted 9th Jan 2016 at 10:52
mocinim
Disconnected the uj from the steering rack put wheels on pulled them in line put steering wheel stright then bolted the uj back on
Real simple if you know how
I did measure everything before and after e.g tie rod ends inner outer turns n all that
Posted 10th May 2016 at 16:44
