Author Subject: Head Bolt Washers
p-silva21
Hi there,
Just release I´ve torqued down the head without using head bolt washers.. The bolts I´m using are Rich´s ones, do you think I´ll have to remove it again or they´ll go fine without them? Unsure
Posted 8th Dec 2015 at 01:42
Did they come with washers ? Can't remember them coming with washers ?
Posted 8th Dec 2015 at 06:23
yes there would be washers under them originally, some bolt types come with washers attached, if the ones Rich supplied did not have any you do need to use the original ones.
Posted 8th Dec 2015 at 09:56
I'm sure he supplies boots with washers ?
Posted 8th Dec 2015 at 10:54
make your bloody mind up Laugh my ass off
Posted 8th Dec 2015 at 11:40
p-silva21
Thanks for your replys!
I remmember removing the old ones to clean up the head but I´m sure I haven´t use them again.. The type of washers that Rich supplies, are they that kind of incorporated ones ( didn´t came off..)?
Posted 8th Dec 2015 at 12:52
p-silva21
Also remmember someone on here saying if the bolts were torqued down without the washers it will crack a water line? Unsure
Posted 8th Dec 2015 at 13:24
craig903
The bolts from rich i got never came with a seperate washer and I had to use the genuine headbolt washers. The bolts do have an integrated washer in the head like quite alot off bolts but nowhere near as thick as the genuine washers.
208 GTI Owner
Posted 8th Dec 2015 at 16:31
p-silva21
Oh dear...Can I remove the bolts and use them again with the washers? Or can´t I re use them because of all stress they have been submitted?
Posted 9th Dec 2015 at 17:16
craig903
I believe rich_w bolts are reusable but your headgasket most likely won't be.
208 GTI Owner
Posted 9th Dec 2015 at 17:18
iron block bolts are not stretch type, should be fine especially if not heat cycled, as for the gasket, im not sure myself, especially as its a steel item as standard.
Posted 9th Dec 2015 at 18:38
p-silva21
Ok, thanks good news about the bolts...The head gasket is the MLS that Rich also supplies! What can be wrong with the gasket?
Posted 9th Dec 2015 at 18:43
p-silva21
Just to clarify, the engine never runned with these bolts and gasket! It´s a forged engine I´m being rebuilted for ages...
Posted 9th Dec 2015 at 18:46
craig903
I believe Rich's gaskets have a copper ring in them, a bit like a crush washer and copper washers you would normally use once and then throw it away.
208 GTI Owner
Posted 9th Dec 2015 at 20:10
mechanical_repairs
Surely remove one bolt at a time and refit a washer and re torque, as the engine hasn't been ran it will be fine, do one at a time. That's what I would do anyway, I have had bolts delivered to be before that haven't had washers and they have been fine also.
It's the 205 lumps without the larger spacer style washer over the water pump that causes the issue with cracked blocks.
Carl
Posted 9th Dec 2015 at 23:07
demondriverdan
Maybe I've just taken them out but I've never seen head bolt washers on the 3 or 4 engines I've taken apart? I presume they must all still be in there then!
Rallye Race Car
Posted 9th Dec 2015 at 23:28
rich_w
You don't need washers with the bolts Smile
Contact Details:
07732 822546
Posted 12th Dec 2015 at 21:53
p-silva21
Thanks for all your help! However, I had already followed Carl´s advise and removed the bolts one by one and replaced the washers... Craig903 I didn´t understand right if the problem you´re saying about the HG was the possibility of a smashed small rivet that would interfere with the alignment of the layers but I´ve checked the old gasket in the engine (also Rich´s one...) and it was absolutely intact and with no signs of a any failure even with all that time/pressure aplied
Yes
Posted 13th Dec 2015 at 20:38
