Lexus light plug and wires
Stock rear cables, phase three.
| Author | Subject: Lexus Lights |
shabusta
Regular Location: Australia Registered: 10 Sep 2015 Posts: 244 Status: Offline |
You can buy link looms for Lexus lights if you insist on fitting the awful looking things.________________________________________ ![]() |
shabusta
hahaha, its more a safety thing, i found the OEM ones either as they are or by age are too dark,and i have had people complain that it is hard to see me. and i got the lexus lights for $40. |
matt16v
Regular Location: SE Registered: 24 Jul 2011 Posts: 217 Status: Offline |
When's the body kit going on?![]() Must be something up with yours if they're too dim. Nice and bright when working correctly. ________________________________________ 1999 Astor Grey GTi-6 OEM+ |
shabusta
Hahaha oem light i cant plug the lexus lights in different connections |
kill it with fire!!!!!________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
gnrlee
Forum AdminLocation: Leeds Registered: 20 Aug 2005 Posts: 8,891 Status: Offline |
Worst "mod" you could do,...Looked s**te in 1997! ![]() ________________________________________ Proud Member of the ASTOR Owners Club |
shabusta
Only body kit i will ever do is a MAXI!Are we talking about the lights or the kit? |
RetroPug
If your rear lights are too dim something is probably wrong.________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
Puggitt
Regular Location: New Zealand Registered: 07 May 2012 Posts: 293 Status: Offline |
RetroPug wrote: If your rear lights are too dim something is probably wrong. What this guy said! It'll be a bad earth, pretty common fault here with 306's in NZ |
shabusta
New Zealand!!!! good to sea someone else down here in the southern hemisphere.they work "fine" i think it is just the bulbs getting old, i'll either steal them from the lexus lights, or this week or next do up some wiring ideas to just cut them and re do it for the new lights. |
mik
Seasoned Pro Location: Kent Registered: 17 Feb 2011 Posts: 2,100 Status: Offline |
Start with cleaning any dirt out of light housings and checking/cleaning connections and bulb holders as well as cleaning and re-securing earth points. Renewing wiring to earth points with thicker wire will also help, as wiring resistance increases with age and corrosion causing voltage drop and dimmer lights. Renewing bulbs with LED bulbs might help too - they have lower current draw than standard bulbs. Those Lexus lights look awful and won't address above problems, I'd stick with standard lights. ________________________________________ Cherry Rallye SOLD |
