Have checked earths and they are all as should be all be it someone bodged the 2 earths on the box that I have fixed now ?
| Author | Subject: Battery light issue |
Ok so I have no battery light on first click of the ignition or second and when I fire up the car the battery light comes on after a min (dim but on) I have put another alternator on and getting 14.4 volts at the battery so something must be a miss somewhere for the battery light not be working as it should ? Any ideas ? Had the dash out recently to do matrix but everything works so doubt I missed something. Have checked earths and they are all as should be all be it someone bodged the 2 earths on the box that I have fixed now ? |
mocinim
Seasoned Pro Location: The Darkside of bedford :) Registered: 09 Jan 2015 Posts: 2,307 Status: Offline |
Loose bulb ?________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
I doubt it bud as it lights up when car running but I am leaning towards it being clock related |
mocinim
Only mentioned as one of my side repeaters does the same kind of thing the vibration of the engine and all that!!! Has a loose bulb due to be replaced with everything else ![]() ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
I think it may be a fuse issue as doing a search fuse 28 causes problems and the rear wiper is also not working ? Will have a look when I get back to the car in a couple of days ? |
tvrfan007
Seasoned Pro Location: In the garage Registered: 29 May 2005 Posts: 3,488 Status: Offline |
I was going to say, look at the rear wiper fuse, it'll be blown and the cause is the relay mounted on the rear wiper motor that will be corroded.I recall that fuse does a lot, i.e. i suspect your electric windows are also not working. Had this on my HDi many moons ago. ________________________________________ I'm Si btw![]() Night Blue VW Golf GTD Bianca LBSC Rallye - Track/Road Slag Project Thread Sparkling Silver Mini Cooper D - Super Dooper - (The other half's wheels) |
It's a Rallye so keep fit Windows but will check the fuses |
stan_306gti6
As above, that blue relay on the rear wiper is the cause of many gremlins. Once removed/replaced end of issue.It may not fix your problem, but definitely worth a look mate. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Fuse 28 it was - changed that and it all came back to life as it should |
stan_306gti6
Glad you found the issue mate, useful info to know.________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
