Advice please
| Author | Subject: Power supply to double relay |
Puggitt
Regular Location: New Zealand Registered: 07 May 2012 Posts: 293 Status: Offline |
I've been hunting down a fuel pump not priming issue and I've dot back to the double relay not being powered up. What I've got to is that pin 2 isn't getting powered and apparently is a permanent +ve which is the switcher circuit for the relay that drives the fuel pump and ignition coils. The main power for that circuit is there but because it can't switch it's not powering up.Advice please |
demondriverdan
Have you got a Haynes manual? There's some useful wiring diagrams in there which should help you find the issue. I think I have an online copy somewhere if needed________________________________________ Rallye Race Car |
Puggitt
demondriverdan
Presume you've checked the inertia switch? That cuts power to the relay________________________________________ Rallye Race Car |
Power to that comes from the ecu. Generally won't if you have an immobiliser or ecu fault ________________________________________ Nothing to see here |
Puggitt
adam b wrote: Power to that comes from the ecu. Generally won't if you have an immobiliser or ecu fault What would cause the ecu or immobiliser to fault? Still I paired set with correct keys etc, |
cully
Seasoned Pro Location: Cullompton Registered: 12 Jun 2013 Posts: 1,093 Status: Offline |
1st side the relay is controlled by the key = fuel pump is it priming2nd side the relay is ecu controlled by the immo to see if ecu is unlocked you will need to get it on planet there is a fuse that blows that will stop the ecu i forget the number favorite issue for fuel pump not priming are fuse inertia switch burned double relay base burned double relay burned cable joints under dash (above passenger feet two loom plugs) faulty pump have you had the engine out recently or disturbed the alternator? check the second white wire is connected to the battery + at the alternator this powers the engine loom (larger ring ta |
Puggitt
cully wrote: 1st side the relay is controlled by the key = fuel pump is it priming 2nd side the relay is ecu controlled by the immo to see if ecu is unlocked you will need to get it on planet there is a fuse that blows that will stop the ecu i forget the number favorite issue for fuel pump not priming are fuse inertia switch burned double relay base burned double relay burned cable joints under dash (above passenger feet two loom plugs) faulty pump have you had the engine out recently or disturbed the alternator? check the second white wire is connected to the battery + at the alternator this powers the engine loom (larger ring ta ![]() I've jump wired the plug and can get the fuel pump to run, so that means it's not a fuse/ inertia switch fault. Engine has been out but haven't disturbed the looms at all just undid them from the chassis leg and left them to dangle. |
have you connected the white cable to the alternator?________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Puggitt
Well I haven't removed it so I assume it's in place, but I don't like to assume, will check in a week after a trip to Rarotonga |
