Author Subject: Inlet manifold support bracket
6box
After the support bracket that sits under the inlet manifold and is bolted underneath?
Posted 13th Nov 2015 at 10:09
Pretty sure I have one of those kicking around in a box of bits. I shall confirm later.
  • Posted 13th Nov 2015 at 10:59
    cully
    think there are two
    one is in the centre of block to centre of manafold
    second is from gearbox front edge to throttle body end of manifold
    Posted 13th Nov 2015 at 12:22
    6box
    thanks for that.
    yeh i have the one near the gearbox i think sits around the throttle body area?
    just after the on that sits in the middle of the manifold Thumbs up
    Posted 13th Nov 2015 at 12:53
    There are indeed 2 and they are important. I had a 6 in at work the other week with a misfire and eventually turned out to be an air leak on the inlet gasket and once I took the manifold off its support bolts were missing. The gasket had been warn away where the manifold was flexing up and down.
    Posted 13th Nov 2015 at 13:16
