Author Subject: Oil cooler fitting
martinh
Have got an oil cooler with a Mocal thermostatic sandwich plate that I want to fit to my 205 with a gti6 lump.
I have read the threads about getting the extended threaded section etc but mine already has it fitted I think, My issue is that even with that fitted there is no thread which comes out past the sandwich plate. Am i being thick or do I need something extra to allow me to fit it?
Thanks
Posted 8th Nov 2015 at 13:31
fatlapit
U need the bolt bud
Posted 8th Nov 2015 at 13:45
fatlapit
https://www.merlinmotorsport.co.uk/s/oil-system/extension-bolts
Posted 8th Nov 2015 at 13:46
The threaded insert doesn't look like its screwed in very far at all. You may wish to check that.
The adapted piece you need is readily available from Merlin, JJC etc.
  • Posted 8th Nov 2015 at 13:48
    cully
    unless that plate is at 80c the diverter shuttle is stuck in the bypass position Wink
    i suggest you strip that plate and clean the shuttle
    ive had an issue with these not closing due to the shuttle being to tight in the casting
    http://www.306gti6.com/forum/showthread.php?id=164228
    should look like this cold
    Posted 8th Nov 2015 at 14:00
    martinh
    Thanks for all the responses! That makes alot more sense now!!
    Will also check the diverter part, had no idea what it was supposed to look like!
    Does anyone know off the top of their head what thread size I need, Am not with the car now so can't measure it!
    Thanks again
    Martin
    Posted 8th Nov 2015 at 14:08
    cully
    20mm
    double check go to ECP website and look at oil filter for the 6 it will tell you the thread
    Posted 8th Nov 2015 at 14:15
    martinh
    Brilliant. Thanks. Will get a suitable one ordered up!
    Posted 8th Nov 2015 at 15:20
