Author Subject: subframe mounting bolts
mocinim
Hi guys need some subframe bolts 12x175 69 bolt no longer stocked by peugeot looking for new cheers
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 5th Nov 2015 at 12:01
just place an order Thumbs up
or go to a nut n bolt shop.
Posted 5th Nov 2015 at 13:41
do some lateral thinking, berlingo/partner are the same front end.
3509 56
SUBFRAME FIXING SREW
12X175-69
Posted 5th Nov 2015 at 13:44
mocinim
Was just going to the nut n bolt place but cheers for the berlingo info im sure thell be easy enough to get at the correct shop
Peugeot lists them as screws wanted to be sure i got the correct parts nothing worse than to stop a job for the sake of a few miss managed bolts
Posted 5th Nov 2015 at 14:01
mocinim
Place an order !! With who do you sell !!!
Posted 5th Nov 2015 at 14:04
try that number with your local dealer, its different to the 306 numbers bu the same spec bolt.
most stuff not stocked can be ordered easily.
Posted 5th Nov 2015 at 14:07
mocinim
Apparently peugeot no longer supply this part for the 306 according to my local will challenge them with the part spec for the berlingo bolt size etc
All other parts for the subframe i have on order through them
Posted 5th Nov 2015 at 14:20
mocinim
Sorry just re read this wandering around london trying to do to many things will work on the suggested cheers welshpug
Posted 5th Nov 2015 at 14:25
mocinim
3509 56
12X175-69
Cheers again welshpug peugeot list these as restyling for the 306 and multiple other vehicles and are correct replacements Smile
Posted 5th Nov 2015 at 16:19
