Author Subject: What aux belt do I need?
bak
I bought an aircon removal kit for my GTI6 more than a year ago. It came complete but the timing belt is older and I prefer to buy a new one. The problem is that I can't see the reference to buy the new?
Can you help me with any brand and the reference? I live in Spain and the 306 without aircon doen't exist in my country so I can't go to the deleader
Thanks
Posted 16th Oct 2015 at 12:18
mocinim
So is the timing belt different to standard thought the aircon ran from the aux belt is there a part that uses the timing belt to run the aircon !!!
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 15th Oct 2015 at 20:34
ac has nothing at all to do with timing belt kit.
Posted 15th Oct 2015 at 20:58
mocinim
As suspected cheers welshpug
Posted 15th Oct 2015 at 21:00
mocinim
Thanks
Do you mean the aux belt fella
Posted 15th Oct 2015 at 21:01
bak
Sorry, the aux belt is the only I need
So, what aux belt do I need?
Posted 15th Oct 2015 at 21:10
mocinim
Not sure myself but there is a thread on here that does say read it about a month back standard rallye one may fit !!!!
http://www.306gti6.com/forum/showthread.php?id=147549 (read me )
Posted 16th Oct 2015 at 08:04
bak
Thank you mocinim, but I can not see the reference numbre of the aux belt in that thread
I see these references: Dayco 6pk1603, SFK 6pk1076, 6pk1165, 6pk1163 and 6pk1610 (but I read that is for standard AC).
I also read the Dayco Drive BeltPart No.: 202991105
So, I have a lot of parts numbers but what is the correct reference for my car?
Posted 16th Oct 2015 at 11:19
mocinim
http://www.ebay.co.uk/itm/PEUGEOT-306-GTi-6-AIR-CON-REMOVAL-KIT-RALLYE-AUX-BELT-AND-TENSIONERS-KIT-205-309/221818724237?_trksid=p2047675.c100009.m1982&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D33957%26meid%3D0db765bf6df7408281b81d6b72408600%26pid%3D100009%26rk%3D1%26rkt%3D10%26sd%3D291582069330
Posted 16th Oct 2015 at 11:50
mocinim
Put this in ebay look on the box in the pic
Posted 16th Oct 2015 at 11:52
bak
I see the reference 6pk1165, is this correct? I read that the most usefull was pk1163???
Both of them are correct? or only one?
Posted 17th Oct 2015 at 11:26
mocinim
Dont know fella best ask you peugeot dealer for exact part number and then reference with what you find im guessing it will depend on what adaption kit model or make you have
Posted 16th Oct 2015 at 12:26
mocinim
Should be a rallye belt in any case
Posted 16th Oct 2015 at 12:27
mocinim
bak
I can not go to my peugeot deleader because the rallye does not exist in Spain. I tried this last geek.
I will check my aux parts number this afternoonI
Thank you for your help
Posted 16th Oct 2015 at 12:57
just ask them for an XU10 non ac belt, that's all a rallye is, its not specific to a rallye.
see link below for specific details for your car.
just go to a local motorfactor.
Posted 16th Oct 2015 at 13:37
bak
The other part number is 122965
Posted 16th Oct 2015 at 16:01
bak
I check with my local motorfactory and they said me that the 6pk1165 and 6pk1163 are the same reference for Xsara and 306 2.0i 135cv and the 306 2.0 122cv and the 306 sedan TD92cv all of them without air conditioner so both are correct
I hope that this thread help other dummies as myself Big grin
Posted 17th Oct 2015 at 11:45
mocinim
Theres nothing dumb about reserching for the correct part mate good luck with you conversion
Posted 17th Oct 2015 at 11:55
Nose
Hi bak, i'm sure it's a 6PK1160 belt you need, this is a GATES part number. Basically a 6 rib belt, 1160 mm long.
Bianca 306 Rallye.
Mondeo Titanium X.
Posted 18th Oct 2015 at 08:34
6PK1163 is the correct part, although 6PK1160 and 6PK1165 will both work also. Yes
Posted 18th Oct 2015 at 11:32
Nose
You're bang on sir, just found my original paperwork, it is 6PK1163 Thumbs up
Bianca 306 Rallye.
Mondeo Titanium X.
Posted 19th Oct 2015 at 13:32
