Author Subject: Saftey devices Half cage
burnout21
Trial fitted a cage I bought off someone. (From a 306)
Its a saftey devices (bolt in) half cage. Its going in my Xsara Vts track car build. Is the gaps correct going off the pic? Or should it be tight on the roof and the pillars. Was cheap enough that if it didn't fit I could sell on. But I'm thinking there is enough room on top above the seats. But it needs plates welded in the floor to mount it. ][/url]
Posted 11th Oct 2015 at 18:22
looks way off that, if there's a different listing fot the xsara I'd imagine its different enougj
Posted 11th Oct 2015 at 18:50
burnout21
Can't see a half cage for the Xsara, only full cage which at £500+ is a bit much on my budget ATM. I'm running bucket seats and harnesses so I'm wanting something that would save my head if it came to it. I know seems daft skimping on safety but its only abtrack car and not for racing.
Posted 11th Oct 2015 at 19:02
eddy_gti6
That is way off the B pillars should be a nice snug fit
Posted 11th Oct 2015 at 19:23
burnout21
Got to workout how I can sort a roll cage out without sacrificing my head. Or redoing this one. I can weld, but not good enough to make a cage up Sad
Posted 11th Oct 2015 at 19:36
rallye1999
That looks nothing like the safety devices cage I had
Posted 11th Oct 2015 at 23:48
burnout21
It didn't cost me much, I'm assuming that the gaps on the sides wouldn't be safe. But on the roof it looks higher than the seats.
Posted 12th Oct 2015 at 09:32
aaron6
Here's a full safety devices cage recently welded in a 306. Very snug fit.
Posted 14th Oct 2015 at 13:33
burnout21
Anyone had one off customcages.co.uk as they have a clubman half cage for less than half the price of an Omp cage?
£254 for a clubman cage ain't bad, which ain't bad for a budget track car. Anyone had any experience with them? Cheers
Posted 14th Oct 2015 at 18:42
Why not save a little longer and go for a multi point weld in cage?
I know they arent cheap but mine stiffened up the chassis loads which made the car feel much nicer afterwards. It's worth the extra money for the stiffening alone, not to mention the added safety factor. Smile
Posted 14th Oct 2015 at 19:12
burnout21
I have been tempted to buy a 6 point cage, nearly bought a Xsara that had one welded in off eBay few months ago, but missed out.
Posted 14th Oct 2015 at 20:40
It might be worth sending phillipm on here a PM, he did my cage and did a top job on it, he will custom make it to your specs. Smile
Posted 14th Oct 2015 at 20:50
i hd a custom cages' cage. i will not get into it now though, the internet will run out of space!
Posted 14th Oct 2015 at 20:55
It was definately custom.
I'm not sure whether it was custom for another car, or if it wasn't actually a cage but a custom climbing frame for a park, but it was custom.
Posted 14th Oct 2015 at 21:01
burnout21
He's pretty busy, been asking him for a lower stut brace for a while 😁 he isn't far so might ask him, priced up some tubing as was considering having a go myself but getting someone else to do the welding. I don't feel confident enough with mine. Got a tube 2" bender. Just getting the angles right.
Do you have a tube bender, or one of those hydraulic pipe benders/crushers ?(tube and pipe aren't the same thing).
Because if it's the latter, it's not going to work on roll cage tube, you'll have to pack the whole pipe with sand just to have a chance of getting it to work right.
Posted 14th Oct 2015 at 21:09
burnout21
Old school pipe bender. Was my late dads, he used it to make sidecarcross frames. Seen CDS tubing online. Just getting the measurements right.
Posted 14th Oct 2015 at 21:27
Something like this?
Posted 14th Oct 2015 at 21:50
burnout21
Will get a picture but its a manual not hydraulic.
Posted 16th Oct 2015 at 08:57
