Author Subject: Bonnet sitting low?
thewho07
Just noticed my bonnet is sitting low at the front drivers side corner, at the headlight. Roughly 5mm lower than what it should be. Had a look at the hinges to see if everything is sitting right, it has been off before as the bolts have socket marks on them - seems fine though. It doesn't look bent or anything. The other side is perfect. Any ideas?
I'll get a pic uploaded shortly
Posted 5th Oct 2015 at 21:20
Is the bonnet rubber set correctly ?
Posted 5th Oct 2015 at 21:24
thewho07
Ah, I'm not at home just now so won't can check until tomorrow. If the rubber wasn't there would it sit lower than usual? I've got a feeling it's probably missing
Posted 5th Oct 2015 at 21:26
Well if it's on one side at not the other then yes it would sit funny
Posted 5th Oct 2015 at 21:27
thewho07
Thanks for that. I'll have a look!
Posted 5th Oct 2015 at 21:28
mocinim
Is your air intake original removal of this can sometimes let it drop
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 5th Oct 2015 at 21:32
thewho07
Yes it's all standard. Thumbs up
Posted 5th Oct 2015 at 21:34
thewho07
Well just checked to see if the rubbers are sitting correctly and they seem fine. Don't really know what else to check... Dunno
Posted 7th Oct 2015 at 20:13
Get a pic up it'll give us a better idea Wink
Posted 7th Oct 2015 at 20:35
iplay
Did you leave something in the engine bay that makes the other side higher?
Posted 11th Oct 2015 at 08:08
