Author Subject: Snapped locking wheel nut
Cjwatson27
Hi after trying to remove my td pro 1.2 s from my v6 i snapped the locking wheel nut key and bolt, ive manged to remove the other 3 by hammering on a multi hex socket, but the orginal won't budge any ideas there's only 10 mm left of the offending bolt the rest snapped off and is stuck in the key.
Posted 4th Oct 2015 at 17:12
Ben_W
Formerly gpm
Drill it........
Utter pain in the arse when this happens. Normally, you can hammer a socket on....unless you are any good with a welder and can weld a socket to the stud, it's drill time.
Posted 4th Oct 2015 at 17:30
Cjwatson27
Tried drilling, what bits would you recomend ?
Posted 4th Oct 2015 at 17:36
Ben_W
Formerly gpm
Big f**k off sharp ones.
A decent set of metal drill bits, sharp ones, will do it. Plenty of cutting fluid, wd40 does a good job. Low speed on your drill and take your time.
Posted 4th Oct 2015 at 22:54
chiefton
Hammer and punch,make an indenting wheel nut and hammer round.
cherry rallye daily (the money pit)
Posted 5th Oct 2015 at 01:03
mocinim
Drill with a tungsten bit as close to the thread as pos hammer in screw driver twist out the heat from the drilling should shift it if you can get a reversed tap bit that fits it will make things easier
(Dont force the drilled old stud into the thread will cause it to stick more best way to drill the centre is to centre punch the stud before drilling try to centre the drilling it helps
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 5th Oct 2015 at 01:27
Have you got this sorted Chris ?
Posted 6th Oct 2015 at 18:27
Cjwatson27
Nope waiting for some Irvin damaged bolt things to turn up, they look like they might work. For s**tty wheel bolts that snapped so easy it proving very hard to drill though. Think it's my cars way of keeping it self alive abit longer .
Posted 6th Oct 2015 at 22:38
