Author Subject: Earth fault?
walker_texasranger
Chaps,
Bit of an odd one this... Been driving my latest Rallye for the last week with no issues whatsoever, then last Friday it cut out on me three times and Saturday four times for absolutely no reason. I've had dodgy ICV's before and that's definitely not the problem here.
It was giving me an ABS warning light every now and then so I made a mental note to get them checked. Friday morning going up a long straight at 70mph everything died. I pulled up, ignition off, ignition on again and everything was fine. Drove another 60 miles with no problem. Later the same day, same thing but at 30mph, only this time it gave me two warning lights. It's also illuminated just about everything on the dash without cutting out, odometer goes blank then back to normal again. It drives absolutely fine aside from this.
It's going in to be looked at next week but I'm thinking its a voltage issue or earth fault. Anyone got any ideas as to where to start?
Cheers,
John
Hilux InvincibleX daily
306 No.13 Doh
Posted 4th Oct 2015 at 12:36
mocinim
Is the ecu correct had a very simular issue with one i used to own someone had chipped it in the past with a third party ecu went like stink but randomely shut down intil reset was something to do with the earths they had been spliced
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 4th Oct 2015 at 13:06
mocinim
Fuse box in engine bay
Posted 4th Oct 2015 at 13:07
walker_texasranger
When you say third party you mean aftermarket?
306 No.13 Doh
Posted 4th Oct 2015 at 13:08
walker_texasranger
Fuse box?
306 No.13 Doh
mocinim
Yea aftermarket supplied by a third party e.g not peugeot or oe licenced manufacturer the ecu i had looked different had no ident on it no sticker or markings
Wiring was earthed linked through the fuse box in the engine bay next to the abs pump was a proper chop job
Posted 4th Oct 2015 at 14:15
walker_texasranger
Just checked and everything looks straight to me, probably rule that out TBH but thanks Thumbs up
306 No.13 Doh
Posted 4th Oct 2015 at 15:41
Check the battery terminals for cleanliness. Had this issue just the other day myself. Thumbs up
Posted 4th Oct 2015 at 15:47
walker_texasranger
Nice one Stan, I'll have a look at that. It's got some weird twist down positive terminal that I've never seen on my previous 11 of these s**t boxes which is odd Huh? LOL
I'll give them a clean and see what's what Thumbs up
306 No.13 Doh
Posted 4th Oct 2015 at 15:59
walker_texasranger
Faced with one of these for the first time ever...
So unscrewed it and found the terminals and connector absolutely packed with grease
Dismantled it
Cleaned everything up, stuck it all back together so see what happens! Did the same with the negative terminal too as that was covered in the same.
306 No.13 Doh
Posted 4th Oct 2015 at 17:55
mocinim
Have the red twist down on mine 99 rallye
Posted 4th Oct 2015 at 17:56
tvrfan007
I have that on my rallye too, seems ok.
I'd have a look at your gearbox earth. Mine lit up the dash like a christmas tree on the HDi when it snapped. Only difference was I couldn't restart.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 4th Oct 2015 at 19:01
Gearbox earth and chassis earth.
The red screw thing is a standard part
Posted 4th Oct 2015 at 19:42
Check the dash earth point drivers side A pillar by the bonnet pull
Posted 4th Oct 2015 at 19:43
walker_texasranger
Thanks boys!
Anyone got a diagram for all the earth points??
Never seen a battery connector like that in 8 years of 306 ownership LOL Every day is one of those school day things...
306 No.13 Doh
Posted 4th Oct 2015 at 20:03
walker_texasranger
Well, drove the car 40 miles yesterday with no issues. I'm counting my chickens but I'm hopeful that's solved the problem Smile
306 No.13 Doh
Posted 7th Oct 2015 at 15:22
heliosphan
Hope it's fixed for good but if problems persist, check the nut fitting next to the red clamp. It holds a few main 12v supply wires together and I had similar symptoms to you once which turned out to be that nut being lose.
Posted 7th Oct 2015 at 22:14
mocinim
What did you do in the end just the to earth and battery or all earth
Posted 7th Oct 2015 at 22:23
walker_texasranger
Not solved Sad
I've checked the earths and they LOOK ok but I'm going to get someone who actually knows what they are doing to have a gander.
One thing is... It's cut at virtually the same point on the bypass three times now, I could point to a spot on the map as to where it's going to happen Hmm always seems to be bang on five minutes after I've set off from home Dunno cars got some unknown aftermarket fob immobiliser installed, could that be faulting? Need to get it hooked up to a laptop and see if there are any codes being thrown up.
I was sat in the car yesterday with the ignition completely off and the fuel pump must have primed five times in 20 minutes. Not normal...
Curious this one!
306 No.13 Doh
Posted 15th Oct 2015 at 09:50
walker_texasranger
Cheers Tom, I'll have a look at that Smile
306 No.13 Doh
Posted 15th Oct 2015 at 09:48
Had issues with bad earth lead from battery to box then to chassis bud check them all ? Mine looked ok but turned out to be dog pooh - swapped it for a nice new one and all was sorted also check the underside of the screw down red but mine was corroded a quick clean with some wire wool sorted that
Posted 15th Oct 2015 at 09:58
hugovox
Ill bet you is something related with the fuel system, maybe a faulty pump or a collapsed hose, a few years ago I had a Citroen CX that stopped always at the same place (3 times). It was the fuel pump!!
Posted 16th Oct 2015 at 16:44
