Author Subject: Knocking engine mount
Kenan
Hi guys, I have change the upper engine mount and the buffer thing that sites with it. The loud knocking is now gone but there is still a random light knocking that seems to be coming from the same area.
I spotted a thread on here where someone advised jamming something solid down by the buffer, can I ask why you need to do this (might resolve my issue?)
Posted 2nd Oct 2015 at 20:25
mocinim
Shouldn't be knocking if its in correctly
did you check the steel around the mount base sometimes needs ablob of weld if its been collecting moisture otherwise best to take a short vid post it on YouTube and set a link tis always hard to diagnose on a discription
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 2nd Oct 2015 at 21:58
Kenan
The knock is almost like a rattle anf very faint, no video would pick it up. I'm sure the old mount was loose when I took it out, better have another look.
Posted 2nd Oct 2015 at 22:15
Was the chassis leg where the mount screws into in good condition? These are very common to crack.
Posted 3rd Oct 2015 at 08:44
Kenan
Yeah I checked that looked good to me, 2 owners ago painted this section.
Is the mount screwed into the chassis or is there a threaded bolt/plat underneath?
Posted 3rd Oct 2015 at 09:10
psjunkie
Captive nut under chassis plate
1997 P1 Gti 6 Charged
Posted 3rd Oct 2015 at 09:46
The bottom part of my rubber top mount once broke and that rattled under certain circumstances. Not really any help for your situation though.
Posted 3rd Oct 2015 at 10:10
Kenan
Ok, took it all apart again and the engine mount was loose. It had unwound it's self?!? not sure how so tightened back up and put some thread lock on (it all helps).
Now any noise is gone, not sure why it unwound it's self??
Posted 10th Oct 2015 at 14:21
cully
hammer and large screwdriver on the castle turrets on the mount then knock it around till tight Wink
unless you have the correct tool
Posted 10th Oct 2015 at 15:11
Kenan
Ah, so it need to be that tight.
If it comes loose again I'll get the hammer out.
Posted 10th Oct 2015 at 15:19
