Author Subject: What is this leak?
ad
Hi people, I've changed my clutch cable today and when I took the under tray off I noticed an oil patch on the tray and a damp patch around the bottom of the gearbox/ flywheel joinSad I have recently bought the car and it had a bit of work done to it including having a reconditioned rallye gearbox and clutch ect fitted. I've been driving it for about a month and it seems fine in all gears.
I've used the search button and from what I've read it sounds like it could be a seal/ o ring that's gone maybe?Dunno I was kind of hoping it would just be the drain plug but I don't think it is. I'm also not sure weather it's engine oil or gearbox oil that's seeping out? I'm just after a bit of info really to see if anyone else has had the same problem or could advise me on what it could be before I have to take it to someone, which I don't want to do as I'd rather do it myself but I've never had a gearbox off one before.
Any help or advice would be much appreciated.
ad has attached the following image:
Posted 19th Sep 2015 at 20:06
ad
Angry
Posted 19th Sep 2015 at 20:07
crank seal behind flywheel or main bearing hockey stick seals, if the box is fresh it shouldnt be leaking
Posted 19th Sep 2015 at 20:16
mocinim
Worst case internal small seals best case driveshaft seals however could be a pipe or s**t from above i realise this isnt much help but leaks are a pain in the arse to diagnose from a pic due to where it is whilst driving leeks spread everywhere
had a simular positioned leak on mine turned out i had a tiny hole in the pas pipe spraying onto the block
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 19th Sep 2015 at 20:23
ad
This is not what I wanted really and I know that what ever it is will be a pain to get changed. I might just get it booked into pug1off and have it done unless anyone knows someone on here local to me that could do it. Either way I want it doing as I don't like seeing leaks. I've got it booked into a body shop on Monday costing me about £300 which could of gone towards this leak. It's always something....
Posted 19th Sep 2015 at 22:06
mocinim
O yes the old car money pit senario pug1off are good but pricy
Posted 19th Sep 2015 at 22:11
Cjwatson27
I think my car will go to pug1off for a cam belt change in the near future, already lost on engine due to the garage timing it up wrong
Posted 19th Sep 2015 at 22:14
ad
I have used pug1off before for a few bits and was happy with their work plus they are up the road from me. The prices aren't to bad I don't think, I'd rather it go to them than a random garage. I also need the the back end going down a notch.
Posted 19th Sep 2015 at 22:30
mocinim
They rebuilt my engine cost a pretty penny but what a superb rebuild shes now awsome i do rate them no one will touch myengine but them in the future the rest i will do but the engine will be looked after by them
Posted 20th Sep 2015 at 01:48
