Author Subject: coolant pink or blue
mocinim
Hi all trying to find out the difference between pink and blue coolant is there much difference apart from price
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 18th Sep 2015 at 14:49
yes it's to do with the life of it
get the luminous green one Big grin
Posted 18th Sep 2015 at 14:54
mocinim
Tell me more rikky does the pink not last as long which is better for engine cleaning im guessing that green is better then
Posted 18th Sep 2015 at 14:58
generally:
pink 5yrs
blue 2yrs
Posted 18th Sep 2015 at 15:00
eddy_gti6
Pink is for girls
blue os for boys
Posted 18th Sep 2015 at 15:17
mocinim
Thanks eddy a truly technical and dynamic view
Cheers rikky
Posted 18th Sep 2015 at 15:21
scotzman
I wouldn't worry about how long it will last, the car will probably have a leak or you will will have had to replace something on the coolant circuit long before then.LOL
Posted 18th Sep 2015 at 16:49
cully
pink for my girl mixed with deionised water Wink
Posted 18th Sep 2015 at 17:22
mocinim
Pink ! Mine to and correct scotz i have a leak somewhere cant find it water doesnt seem to go down much at all but i can smell it after some sprited driving my guess it's a tiny hole spraying on and evaporating reacon ill change all my pipes that is already on the list of things to do
Posted 18th Sep 2015 at 17:53
If you can smell it in the car will be heater matrix starting to leak.
What ever you do don't mix pink and blue coolant they can crystallise and royally f**k the block up. You can mix pink with red, blue with green. It's generally regarded that pink is the best but I could t tell you the ins and outs to be honest.
Posted 18th Sep 2015 at 22:22
mocinim
No the smell comes from the back of the engine area will change all the pjpes then will attempt the matrix!! dash out time that could be good however have a short on the old speaker wire last places to check are under the carpet or behind the dash
And would never mix any of the fluids full job or not as it goes but cheers for the info armzs good to know
Posted 19th Sep 2015 at 08:53
allanallen
Colour has nothing to do with anything, the manufacturer dyes their coolant whatever colour they wish, it has no baring on anything. A single manufacturer may dye their 2 year coolant blue and their 5 year coolant red but it doesn't mean another manufacturer does the same.
Good info in this thread from the technical guy at millers oils
http://www.alfaowner.com/Forum/engines-ts-jts-jtd-andamp-v6/266301-coolant-andamp-antifreeze-explained.html#/forumsite/20947/topics/266301
Facebook
Posted 19th Sep 2015 at 10:25
mocinim
Cheers allan what is your prefered manufacturer of coolant
Posted 19th Sep 2015 at 11:06
allan said always use the pink one, whether it's antifreeze, socks, tshirts, etc
take a look at long life antifeeze and see how many are any other colour than pink Unsure i can't see why they'd just dye it any colour they wish when so much long life is pink only. it can't simply be myth, there has to be a reason why most of the long life is coloured pink and the normal stuff blue (IAT etc)
Posted 19th Sep 2015 at 12:25
cully
OAT coolant will work if your radiator is aluminum, OAT in a copper radiator is not recommended as it dont like soldered joints Wink
Posted 19th Sep 2015 at 13:22
allanallen
You'll be pleased to know I had a pink shirt on last night rikky! Razz
Last longliife I had was luminous green! I do agree though, a lot of the longliife from factors is pink/orange
Facebook
Posted 20th Sep 2015 at 08:52
