Author Subject: Clutch cable or deeper issue?
gatorboots
Hey guys, new user/owner here. Unfortunately my first post isn't a happy one Sad
About a week ago problems started when a few gears felt stiffer than normal to engage. Seemed to happen out of the blue.
Sometimes it will shift fine as it has always done and sometimes the thing wont budge at all, having me resorting to turning the engine off to stick it in gear.
The clutch pedal has more than normal free movement at the top (started at the same time) and only engages at the very bottom of the pedal.
So i took it into a pug specialist for a quick look and they noted excessive movement at the clutch lever but couldn't give me a solid diagnosis. They suggested a cable replacement as the first thing to try, but suspected a deeper issue may be to blame.
Would appreciate some expert knowledge Smile
Posted 15th Sep 2015 at 07:53
mellowr1
Mine did this. Self adjuster on cable stopped working. New cable sorted it
Posted 15th Sep 2015 at 10:15
3rd time lucky
Shock Shock Shock Mick.... Is that you.....?
BLACK RALLYE - Sold
CHERRY RALLYE - new toy
Posted 15th Sep 2015 at 12:04
Sounds like the cable to me aswell.
Posted 15th Sep 2015 at 12:06
gatorboots
Okay thanks guys, that's what I was hoping to hear. I went full on bandit and put a cable tie through the plastic piece that connects to the back of the pedal as a spacer which takes off a fair bit of the slack on the cable and it seems to help. So i guess that confirms it's a cable issue haha.
Posted 16th Sep 2015 at 09:17
mocinim
A nice dura cable is only 20 bucks worth changing anyway when changing the clutch seems silly not to
This comment pointed at a garage i used not so long ago hmmmmmmm
And regularly causes poor pedal motion when not done
Try some bv oil in the old box chap did wonders for mine
£15bucks 2 litres bish bash bosh and its lovely Smile
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 16th Sep 2015 at 10:41
My 306 1.9 Diesel not my 6....has just done 110% same thing with same symptoms but tonight started to creak .....then found out after clutch stopped working .....using a small bright torch & small mirror through gearbox view plastic plate cover that the Bearing has gone into & nearly through the pressure plate .....new Clutch kit & two forks bushes & Crank oil seal for me then Whistle
I'm going to fit a clutch cable as well Thumbs up ......it's my daily Razz
Should I go .....Sachs or Valeo ?
Posted 18th Sep 2015 at 23:19
mocinim
Valeo
Posted 19th Sep 2015 at 00:20
on a 1.9 d it wont matter, sachs do o.e stuff so its decent quality anyway.
i the cars have never had a clutch its likely to need one soon, even if its not slipping, fork bushes will be worn, shafts rusty, and clutch springs stiff.
Posted 19th Sep 2015 at 09:05
