Author Subject: Satchshift with dpengineering manifold
craig903
Hi would anyone know if the satchshift kit would fit with a dpengineering manifold and down pipe? I suspect not but I'm not sure.
Thanks
208 GTI Owner
Posted 26th Aug 2015 at 09:39
Thanks
I wouldn't have a clue ...but what I do know is make sure you fit the Satchell shift ....amazing bit of kit
Posted 26th Aug 2015 at 13:23
craig903
Yep I've heard that too but I don't know if there is enough room for the bar to go threw the bulkhead because off the down pipe.
208 GTI Owner
Posted 26th Aug 2015 at 15:02
pugheaven
I doubt you will have enough room, not a lot of space with the standard exhaust manifold and down pipe
Posted 27th Aug 2015 at 11:50
demondriverdan
Should fit ok with a Maniflow 4-2-1 as that takes up less space?
Rallye Race Car
Posted 27th Aug 2015 at 12:13
Chr1sch
Does anyone else's Satchshift reverse selector rattle a bit when changing gears?
I think second is a bit tired in my box which makes the change bloody hard too when cold...
As others have said it's mega right under there so unless your manifold is indeed smaller than standard i don't fancy your chances
Posted 27th Aug 2015 at 12:27
heat shouldn't many any noticeable difference if you have the right oil.
Posted 27th Aug 2015 at 12:39
craig903
I've had a look under my car the down pipe goes right in front off where the hole needs to be drilled threw the bulkhead
208 GTI Owner
Posted 27th Aug 2015 at 13:54
Not mine Whistle
Posted 29th Aug 2015 at 22:54
